AT commands from PLC
Jan 2013
Rizal
Hi everyone.
Can anyone help me on how to send AT commands through my Omron PLC?
What I have is a GSM modem connected to the built-in RS232 port of my CPU.
Or if you have documentation or an online source, please do refer, I could just read I would be fine with that.
Please help me.🤞🏻
welcome to the site
you need to specify which Omron PLC
there is a direct TX and Direct RX command in the CJ series
Hi Ian!
Thank you for the response:)
I'm using CJ1M.
I've kinda figured out already that I'll be using TXD and RXD commands.
But what I was still confused about is how to input the commands in the PLC data memory.
For example for the sending command:
at+cmgs= "639161234567"<CR>TEST.<CtrlZ>
should I be converting each character (whether letter or number ) to its HEX equivalent?
I've read the manual for TXD and RXD instructions. I didn't understand how "@GL" would become 40534E.
40 would be for the @ sign but I'm not sure about the rest. :unsure:
Thank you again for helping me out. (y)All these stuffs are pretty new to me. I don't want to waste more time learning everything on my own. I have to ask help sometimes.
Give me a while and I will post some stuff for you. Have not done it for a while but think I have all the documentation here.
Yes!
I have figured it out.
There's a hex equivalent for each character. Just convert each one. But take note that TXD utilizes a certain pattern; you could have MOST SIGNIFICANT BYTE FIRST or LEAST SIGNIFICANT BYTE FIRST.
For those who would also like to know. Please view attachment.
But I appreciate your help Ian and Bob! :)
thanks much!
AT Commands from PLC
Hi, im using siemens S7-1200 and I have enfora GSM module, please help me how to send AT commands. Thanks
Dear Eemann,
Welcome to the forum. I would recommend posting a new thread, this one is 7 years old and is for a different PLC altogether.
You might also want to specify what PLC and CP/CM you have, as well as your GSM module.
Hi all. This is a very specific issue. My first time with a Modbus ProSoft. Customer setup doesn't make any sense but we're stuck with it...
416
Hi Guys, Got an interesting question, has anybody tried to use a PLC to re-configure a router? I have done so using SNMP (relatively...
1,615
I recently purchased a GSM modem model number SGM510 from a local dealer in Mumbai, India and I am trying to connect it to a Delta PLC that I have...
1,711
Hi everyone, I have Siemens S7-1200 1214C AC/DC/Rly CPU with CM 1241 Rs232 module and Enfora GSM 1208. Help me how to send sms using PLC. Thanks.
2,045
I'm trying to use a Allen Bradley 1769-L24ER-QB1B PLC to send a command from my Studio5000 logic to a Cognex DataMan 262Q barcode scanner...
3,710
