RSLINX OPC client with VB/C++
Dieter
Guest
D
Hi, I am interested in seting up an OPC client due to the robust nature of OPC. I know Rslinks SDK can create OPC clients, but can anyone tell me where to find a VB OPC client that can access all the topics created in Linx. I would be interested to set it up on a local machine and then share the tag info accross RS232 to an electronic display board. Any ideas?
Cheers
Dieter
Dieter,
Try http://www.opcware.com
Have a look at OPCWare Client Developer, it's a suite of ActiveX controls that have OPC client functionality built in. The installation includes VB6 and VC++ samples.
The OPCWareItemExplorer control will allow you to browse all the available tags in an OPC server, if the OPC server supports tag browsing. Off the top of my head I can't remember whether RSLinx supports tag browsing but you'll know straight away if you don't see any tags. For those OPC servers that do not support tag browsing, you can add tags by typing in the tag names, but you have to know the tag names.
Neil.
Currently OPC Client (PI OPC Interface from OSISOFT) is reading the data from RSLinx Gateway which is installed on different PC. And we are...
7,004
Hi, I have a question, when doing controllogix PLC programming, Do we need create special UDT(Continuous Block in memory) for HMI OPC Client to...
4,914
I am newbie to OPC. I have a new OPC test Client which is running on FMC application supplied in package from Thermo Fished Scientific. The...
14,157
Hey Friends. I am currently trying to write approximately 700 tags from FtView13 to an Logix Emulate 5000. I am using rslinx DDE/OPC to create an...
394
Hello All, I know it is possibile to access data from a PLC directly to excel using a OPC link through RSLinx...
1,749
