plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Unread June 20th, 2019, 09:34 AM   #16
bright676
United States
bright676 is offline
I want to use the 8 pin mini din and not having to keep using adapters. We have them on some panels at work, but I will have to wait untill I get back to work to get the model info.
Unread June 20th, 2019, 09:39 AM   #17
Firejo
United States
Firejo is offline
Firejo's Avatar
I always forget about the SLC5/04 (mental block I think). That's very different. You could put a 1784-U2DHP adapter in the panel, have it plugged into a USB hub and access the hub through a pass-thru connection but depending on where you get the DH+ to USB adapter you'd be spending a few thousand dollars. You could replace the SLC5/04 with a SLC5/05 but same issue (cost). I'd open the panel. I don't believe you'll find a pass-thru with the correct connection type but it is certainly worth looking for. Having said that, regardless of what it takes to connect to it, I'd migrate away from the SLC5/04 anyway but that's just me (there is a reason for the mental block).
__________________
Go Hawks!!!
Unread June 20th, 2019, 09:43 AM   #18
geniusintraining
United States
geniusintraining is offline
geniusintraining's Avatar
Quote:
Call me (or email) once you find out what you have... maybe I can make a cable and find a bulkhead that will work, you trying to plug the U2DHP directly into the outside of the cabinet correct?
__________________
www.PLCCable.com PLC Communication Cables, PLC Trainers, Fluke Meters, MicroLogix, ControlLogix, Siemens, Allen Bradley and more... all your automation needs... ((NEW)) After Market 1784-U2DHP Allen Bradley USB to DH+ and Gateways
Unread June 20th, 2019, 03:01 PM   #19
bright676
United States
This will work
I ended up getting this which will be perfect for my application.
Thanks all for trying.
Unread June 21st, 2019, 08:26 AM   #20
Caveman
United States
Caveman is offline
Caveman's Avatar
I have four of these. If interested pm me a reasonable offer.
https://drive.google.com/open?id=1j2...aJhK7Xu7fpHHN7
https://drive.google.com/open?id=198...Pb77hSfNLiUzVr
File Type: jpg EA5F378A-54A1-4255-A167-63AECB2C42C5.jpg (157 Bytes, 20 views)
File Type: jpg 7D74F4AE-C48D-4849-B9D3-8CE6A0D425EE.jpg (157 Bytes, 11 views)
__________________
Farmer PLC Tech
Unread June 21st, 2019, 01:48 PM   #21
bright676
United States
I paid $19.00 plus shipping. Your links do not work either.
Unread June 21st, 2019, 02:38 PM   #22
Bob O
United States
Bob O is offline
Those links worked fine for me.
Good luck!
__________________
There Is A Frost Advisory...GBR!
Unread June 21st, 2019, 09:18 PM   #23
Caveman
United States
Caveman is offline
Caveman's Avatar
I tried to remove the attached, just wasnít able to.
__________________
Farmer PLC Tech
Unread June 22nd, 2019, 05:07 AM   #24
geniusintraining
United States
Great price and a very nice product!
__________________
Unread June 22nd, 2019, 05:22 AM   #25
Caveman
United States
Caveman is offline
Caveman's Avatar
The ones I have, have a handy dandy receptacle with protective covers.
__________________
Farmer PLC Tech
Unread June 22nd, 2019, 07:49 AM   #26
mendonsy
United States
mendonsy is offline
mendonsy's Avatar
That's quite a deal. Graceport lists that one for $146.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Pin Installation Machine pstephens LIVE PLC Questions And Answers 101 November 25th, 2013 10:41 PM
Connector for 8 pin mini din flyers LIVE PLC Questions And Answers 7 May 8th, 2009 05:42 PM
Mitsu Q02H 6 pin mini din Siemens TP170 MattReardon LIVE PLC Questions And Answers 2 January 28th, 2007 02:12 PM
8 pin mini din for 1761-cbl-pm02 needed e-unit 79 LIVE PLC Questions And Answers 4 June 1st, 2006 12:15 PM
8 Pin mini Din male connector Turkish LIVE PLC Questions And Answers 5 October 8th, 2002 11:27 AM
