Trying to access data in SQL 2008 for water quality state reporting
Wag - wild a** gues
Swag - Super wild a** guess
AH ok, thank you for the explanation.
if your customer had a falling out with the integrator and they had access to the pc, I hate to say it, but they may have gotten into the pc and erased the critical programs and files needed to obtain the information you need. I would look at the deleted filed. Warning, be careful of what you find. they may have changed the files before deleting them, if that is what they did.
I have known of this happening, not saying they did.
james
Excellent point. I've heard that the former integrator did in fact log in and shut things down, so deleting files/uninstalling programs is entirely possible.
WAG means Wild A** Guess. I don't know what the "S" is for. This is an interesting post and when you get it working I'll have to take some notes because I'm going to be using SQL data gathering soon. Thanks, guys.
If it's within your budget the eATM module is the best solution for this IMHO.
Plugs into your PLC rack and it's simple drag and drop setup. I have used this module on about 2 dozen applications and every customer has loved it and I have used it to replace some clunky software solutions in a few cases.
They have it for CompactLogix now also.
This will allow you to read and write directly to the SQL DB without using Excel or other software.
Here is a link to the module
https://data-intelligence.softing.c...in-chassis-module/eatm-tmanager-controllogix/
And here are a few videos on it.
https://www.youtube.com/watch?v=CRR0QhoQmGU
https://www.youtube.com/watch?v=zbUySb-N1HQ
https://www.youtube.com/watch?v=UxHsiHKnL84
Not sure what the issue is, there is no security enable on the project and I can download and go online normally. If I hit run to try and trace...
1,790
Out of 21 (near identical) Modules in this system, I have only one available to test on. On start-up I check to see which Modules are not...
4,571
I can't seem to get the Panel View Plus 7 standard edition to downgrade to V_11, when I check the AB downloads and compatibility websites for this...
98
Hi I used to be able to launch PLCsim without any problem. Now it tells me " STEP 7 Professional Licence is required to simulate this PLC"...
454
