brettshelley
Hi Guys,
I have quoted a customer on production displays inside the factory. In the past I have used a GOT terminal with the VGA out card so that the 55" monitor displays the HMI page or using an industrial PC with SoftGOT.
I have now received info that another competitor has quoted cheaper using a Beckhoff Panel PC that can, and I quote from email ---
Basically the system operates on an Ethernet protocol – hence the wiring is very simple.
The system is easily expandable.
We offer a device that will convert the Ethernet signals into the Video signal for the displays.
So instead of me using ten GOT's with VGA out to each monitor, this guy says he can do this with one FX PLC, a Beckhoff Panel PC that is connected to 10 monitors that will each display its own production data via Ethernet to VGA ??
Is this possible and is there a better solution with Mitsubishi??
Best regards and looking forward to answers,
Brett Shelley
Brett Shelley
