GE proficy numeric data entry animation
If you are using the standard Numeric Data Entry item, there is no animation including visibility.
If you use a button, you will have animation objects.
If you have the Inspector window open, any object that has animation will have "Animations" on the general tab.
For further information on what objects support animation, search the help for animation, then open the topic "Animation: an Overview".
The page shows a list of objects for each animation type.
I put a Numeric Data Entry Object(NDE) on my screen. Then I made a rectangle(solid pattern). Moved the rectangle over the NDE and set the...
1,550
Hi I am wondering if the RXI-042 PLC model (below PN) is programable via Proficy Machine Endition, if so, what is the firmware version needed for...
58
Greetings, I am working on a project and I would like to scale %AI to -10.0 to 10.0 VDC. The module Input data is stored as a 16 bit Integer and...
49
I am trying to download a program with usb to serial cable in rx3i IC695CPE305 while logic and configuration is equal but when i start downloading...
31
