Siemens HMI communication with Telemecanique TSX (via Unitelway)
macio
May 2009
Wroclaw
Hello
I am trying to get connection between old Telemecanique TSX47-411 (or TSX 87-425) with Siemens HMI. Protool and WinCC Flexible manuals say that it is possible using Unitelway bus and SCA62 junction box. But manual 6AV6596-1MA06-0AB0 (Communication for Windows-based Systems: Part 2, page 18-2) says:
" For connection of the operating unit, an RS 485 interface card configured as
follows must be used:
- Rx: always on
- Tx: controlled via RTS
Tests performed by Siemens AG involved the use of interface cards of the type
C102, CI 132, CI 132I or Ci 132IS from Moxa Data Communication Solutions."
Does anybody has experience with that kind of communication? What is these Moxa cards for? This is PCI card and I do not see where this should be installed.
Best regards,
macio
Hi, I have Siemens HMI 6AV6643-0CD01-1AX1 with Ethernet port but connected with Siemens PLC S7 314C 2DP on MPI port. Let me know can i get PLC...
2,522
hello dear we have a problem with communicate with delta dop hmi and siemens s7-300 cpu . we use ISO ON TCP connection and AG-SEND and AG-RECV...
3,511
This Problem happened many times, is it only because the wrong type DB10Q0 should be DB1010 or any other possible cause? HMI log file ...
8,578
I have been working on communicating with Siemens KTP600 Basic PN HMI from my microprocessor. The main communication protocol that HMI uses with...
12,630
Hi guys, I need the communication cable between S7 300 Siemens PLC and Hitech HMI. Can anyone help me? Many Thanks.
3,803
