Kinetix 5500S2 Fault FLT S54 POSN Error
zarunas
Apr 2009
Plunge
Maybe anyone can explain what this error means.I Kinetix manual from Rockwell support information is very poor.
We checked all equipment motor,reductor,bearings,betl - mechanically everything is ok.Module revision is 7.001.Maybe it need update to higher version?
Studio500 Logix Designer version is 29.
Thanks for answers
Generally a Position Error is caused by the difference between the commanded position and the actual position being too high.
There's quite a few things that can cause it. Is this an existing setup that has run before with the current settings? If not then likely your tuning or other settings are incorrect. If yes then there may be a problem with the motor or mechanical (motion is commanded but does not occur) or feedback (motion is commanded and occurs but is not seen by PLC).
Hi guys, I have the first Kinetix 5100 in my facilities. I already configure the movement in Speed Mode, I am sending the Analog signal from my...
42
Hi all, I am upgrading a couple of 2094-BC01-M01 servos with 2198-H015-ERS. The original code uses MSG instructions to control (release, engage...
75
Hello all I was trying to autotune a Kinetix 5100, I got an encoder fault and it says to check the wiring. I remove the 24 volts from drive to...
51
Hello everybody, I have Kinetix 5500 (2198-H040-ERS). I'm having issue with this drive. (I believe it's the drive/Kinetix and need confirmation)...
60
in allen bradley kinetix 300 drive first E31 error shows after resting drive E11 error occurs need solution to reset E11 fault code
163
