plc storereviewsdownloads
Reply
Thread Tools Display Modes
Old October 16th, 2020, 05:25 PM   #1
ExSilver
United Kingdom
ExSilver is offline
Unhappy Indirectly Addressing Powerflex 525
Hello All, I wonder if anyone can help me?
I'm working for a company within a sector that has virtually zero standards of work so i've started creating template routines, tag structures etc.
However, i have a query. I don't want to use direct Inputs/Outputs from hardware etc, and i've built a UDT with all the System tags associated with individual drives. (We use multiple Powerflex in a single system)
The Tag Structure from the Powerflex comes in as:
Integer
15 x Booleans
Integer
For both Inputs and Outputs
Now i've built a UDT Containing
Drive Inputs (UDT with the same structure as above)
Drive Outputs (UDT with the same structure as above)
Random System Booleans
Random Reals
Random HMI Inputs
The problem is that cannot move the Raw Inputs/Outputs that are created when adding a drive to the IO configuration into my Drive Tag. (Built as above) because the CPS command expects the element length to be of the same data type. i.e 3 dints etc.
Has anyone got any advice on the best way to deal with this as i dont want to have to manually move the 15 Booleans and the 2x integers separately.
I Hope i've explained this enough. I can provide my UDT for anyone interested. I've normally only dealt with SEWs etc that come in as arrays of Dints. Burning my head out! haha
Thanks in Advance
Old October 17th, 2020, 02:20 PM   #2
rajy2r
Canada
rajy2r is offline
rajy2r's Avatar
You can always create an AOI that does that for you if you have multiple instances.
Generally I would create UDT for the motor structure and read/write the drive tags to/from the UDT as required.
FYI, you posted in the practice section and not form section.
Old October 17th, 2020, 02:38 PM   #3
ExSilver
United Kingdom
ExSilver is offline
Thank you for your response.
I was thinking of an AOI but wanted to keep it simpler. I would have thought that with it being an AB product and them knowing indirect addressing is common in most industries that there would have been an instruction im not aware of to handle this.
Its crazy..
I'll sort the AOI tomorrow.
Thanks again!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
PowerFlex 525 will not start thru Ethernet. Have a Ready signal in Controller Tags Cydog LIVE PLC Questions And Answers 17 November 18th, 2018 07:24 PM
Powerflex 525 PID Controll for a Pump in a Hot Water Set travisroberts88 LIVE PLC Questions And Answers 18 November 10th, 2017 07:24 PM
RSLogix 5000 and Powerflex 525. Elcan LIVE PLC Questions And Answers 4 October 28th, 2014 11:38 AM
Powerflex 525 Multidrive issues Teglaco LIVE PLC Questions And Answers 2 July 14th, 2014 12:57 PM
PowerFlex 525 Open Loop Metering Pump Control Help shiftedbits LIVE PLC Questions And Answers 5 February 1st, 2014 02:15 PM
