Connecting FC 105 block with I/O Field in Wincc V5.0
gigacer
Oct 2014
Osijek
24
Hi, i am beginner with WinCC and i need help, i connected the Temperature transmitter with a SM331 module on PLC so i can read a temperature value in STEP 7. I use FC105 block to read temperature value and all that is working properly. Now i need to display that value in HMI. I am using WinCC v5.0 to do that, specifically the ''I/O Field'' in WinCC. I am using the MPI Communication to connect WinCC with a PLC, but i cannot get the Temperature value in a I/O Field. I always get zero value. Here are the pictures:
1. HW Config
2. FC105 block
3. MPI Connection
4. Tag for the FC105 block
5. I/O Field properties
What am i doing wrong?
hi, again me, i set the slot adress to 2, but again i get zero value, does anyone know what else could be a problem?
i have monitored FC105 block in Step 7 with Monitor icon (goggles)and i get the value on the PIW288, also i get scaled value on the MD240 so the FC105 block is working properly, i just can't get value from MD240 in the WinCC I/O field and i don't know why...
I have a piece of equipment that is operated by a PanelView Plus 600 HMI touch screen via RS232 into a Micrologix 1500 PLC. I am trying to...
108
Hi, Seeking consultation on an implementation matter, and have a question about Modicon Compact 984 communication through RS485: Three Modicon...
82
I have Toyopuc PLC PC10G-CPU and some communication modules of it. With this modules I'm able to connect with Ethernet, Ethernet/IP, FLnet, FRMT...
52
Hi, We are setting up an Aveva Plant SCADA node with the intention to connect it to a Wonderware Historian node. Everywhere I look online I see...
117
Hi; I have Laptop Lenovo Thinkpad (W10) which don't have built-in Bluetooth. I have a PLC having Bluetooth communication device. I wanted to...
82
