Team Leader has Proworx 32 ver 1.1 in desk, will not allow me to upgrade from Modsoft
Sliver
Feb 2004
Kingston, Ontario
488
The technicians were sent on Proworx 32 training a couple of years ago and there were so many bugs that it was decided to stay with Modsoft until the bugs were fixed.
As far as I can tell from this forum the new version 1.1 is working well.
I want to upgrade my laptop's OS that had to be downgraded to Win98 to use Modsoft.
Are there any other obvious reasons for upgrading to Proworx 32 that I can use as ammo to outgun my stubborn, don't want to move out of the 80's Team Leader?
Thanks,
Brian.
Hi all, i have an application in which i need to read the water level in a 1 1/2" diameter tube that is 24 in. tall. the sensor will be mounted...
27
1,971
Hello, We have a startup valve, that has to open on startup etc. We also want to know the flowrate throughe valve. They told me that in previous...
17
2,743
Hi; We installed an orifice plate type steam flow transmitter which configured to give 4-20mA signal correspond to 0-9ton. I given that signal...
24
5,611
The IAPWS-IF97 steam table is used as a measuring standard for the correlation between steam temperature and pressure. The calculation formula(s)...
1,707
Good day Gents, Does atmospheric pressure have an influence of a boiler steam pressure.
31
8,591
