help with abb s4c robot displacement offset
lunknowl
Oct 2012
vietnam
37
hi i try to do a simple program displacement program using PDispOn
PROC move_up_back()
PDispOn *, tool1;
MoveL *, v500, z10, tool1;
PDispOff;
ENDPROC
MoveL p10, v500, fine \Inpos := inpos50, tool1;
move_up_back;
the program is simple move to p10 then move up and back(move away from p10 at an angle)
it working but when i turn robot 6axis 90 degree it not work. it move up and right (the robot dont know 6 axis is turn??)
hope that anyone have more example to show how to use PDispOn property, thanks
I agree with jstolauk, posting at that link or talking with ABB directly could get you some better answers.
That being said...I'll throw this out there.
I haven't done much work with PDisp, but it almost sounds like there is a coordinate system mismatch. World coord. vs. work object for example.
I don't have my test robot hooked up right now so I can't test directly to confirm.
Double check which coordinate systems your targets were defined in. If you had two different coordinate systems being used, you could be getting some unexpected results.
Pi
Good morning folks, I need your help and I am a beginner on PLC and I have been given an assignment on wiring a flowmeter to plc and create a...
2,203
I am using a ACS800 regen drive to drive a 500hp motor for a engine dynomometer application. I am currently running the drive via ethercat...
1,683
Hi, I want to send the data from ML1400 to ABB PLC. Can anyone help me to send the data through MSG instruction setup. Best Regards, Prasanna
1,358
Hi i need your help , Please tell me what is the meaning of 14<<2 and other , thanks
1,237
sir plz tell me how to interface servo motor with abb micrologoc 1400b plc plz give me detail of instruction and wht type driver may i use or tell...
2,496
