Factorytalk View SE Local Station Sluggish/Slow Response to SLC 5/05
JKam55
Dec 2017
Ohio
I am upgrading one of our sites from Rsview32 to Factorytalk View SE Local Station on Win10 and I have the program all set up and switched over but it seems that all of the tag responses are about 3-5 times slower at least than it was with RSView32 (using direct driver).
My setup is this: FTView SE to a SLC 5/05 (1747-L552 32k) PLC. The HMI PC goes straight to the managed switch that the SLC is connected to. The plant itself runs through Devicenet and RIO but we do have one other data collection PC on site talking to the PLC through RSLinx Classic OPC Topic.
Both the SLC and the PC are set for autonegotiation and I have also set all of the (critical) screen displays in FTView SE to below .25 sec refresh rate, compared to the standard 1 sec times. I do not have access to the managed switch settings but I am trying to talk with our IT to see if there is anything they can possibly look at.
The new program does use all HMI tags instead of direct references, which I have heard can cause some delays. From what I am seeing though, the delays seem a lot worse than what would be cause by extra time from HMI tags...
Does anyone have any other ideas for better comms? I feel like I am missing something here.
Thank you in advance for any help.
Thanks Garry.
After reading through a bunch of posts and looking into the plant a bit more, I think the issue is originating from too many connections to the SLC Ethernet.
I removed all Ethernet connections and just tied the FTView SE PC and the SLC straight to an unmanaged switch by themselves and the response time improved dramatically.
I have to wait until later but the diagnostic file for CH1 Ethernet on the SLC is not defined so I am going to download to the PLC and monitor that file but I have a pretty good feeling that's what my issue is. I am not very familiar with how the direct driver works in RSView32 but it is definitely faster to the SLC than the new RSLinx Enterprise connection with FTView SE... Either that or it just simply doesn't bog the system down as much.
I am not exactly sure what can help me out in this situation though if we stick to the SLC unless I change to a L553 64K processor to increase the connection amount... I will have to take a look at some other possible solutions.
Well in case anyone reads this, it looks like my problem did involve the Ethernet comms with the SLC 5/05.
There is a bit in the processor status Ch1 settings S:2/15 that, if enabled, only allows one Ethernet connection to be processed per scan, or something along those lines. I disabled the bit to allow multiple connections to be processed per scan and the difference was very noticeable! The response from the HMI is very quick now and I didn't notice any real change in the PLC scan time either.
Hi, I'm trying to export data from a DataGrid to Excel using VBA, but I'm getting an error "Object doesn't support this property or method". The...
72
Hello everyone, I am having a problem with conversion from RSView32 to FT View SE Local project on version 12.00 (CPR 9 SR 12). Firstly, I have...
1,398
Hello, Does anyone know a Macro command in FactoryTalk View Studio to copy a Datalog database file to a USB drive or some other location? I...
3,663
Hello everyone, I have a line that is currently running an older version SE local station application. I took a backup of it and "updated" it by...
6,017
Hi, I am looking to replace a RSVIEW32 application with FactoryTalk. In addition to RSVIEW, there is a touch paneled PC running Rockwell RAD...
7,258
