Wago 750 codesys 2.3 mitsubishi hmi GX designer 3 with modbus
erki338
Aug 2017
Estonia
Hi id like to connect my wago controller with mitsubishi hmi and im using codesys 2.3 and gx designer 3. Id like to know how i know what register my outputs have. Example %IX0.0 is 00001 i think but what register have %IX1.5
and what %IQ0.0 and %IQ1.1. and how can i make it read/write?
http://global.wago.com/media/2_products/m07500881_00000000_0en.pdf
Check out the above manual for the Wago 750. Section 12.2.4 MODBUS Register Mapping will show you the modbus address for the unit.
MODBUS address IEC 61131
[dec] [hex] address
Memory range
0...255 0x0000...0x00FF %IW0...%IW255 Physical input area (1)
First 256 words of physical input data
[dec] [hex] address
Memory range
0...255 0x0000...0x00FF %QW0...%QW255 Physical output area (1)
First 256 words of physical output data
Hope this helps you out.
Regards,
%IX0.0 -> Modbus Input address of 10001
%QX0.0 ->Modbus Coil address of 00001
%MW0 ->Modbus holding address of 40001.
fpr my %IX0.0 address is 10001 but question was whats for %IX1.1 1.2 1.3 and so on.
and the same for %QX1.0
and right now i can only read those how can i make those write too?
Hi, I have never used modbus communication in Codesys 2.3, any tips and tricks are much appreciated. The system is a Wago 750-881 that controls...
1,843
Codesys Ethernet IP Scanner - Won't connect to a Wago 750-353. The Ethernet device and the Ethernet IP Scanner are both running. but then I go...
1,663
Hello, Maybe it is just a simple problem, but I cannot solve it. I have a Wago 750-881 connected to a Beier HMI through IP TCP, the connection is...
891
Hello, I have recently started learning how to program PLCs using CoDeSys v 2.3 and a Wago 750-871 controller. Thanks to a couple of forum...
3,513
I am using Codesys and have an offline copy of the PLC program. I am trying to login to a Wago 750-881 that supposedly has the same program...
4,488
