Connecting and configuring CP1430TF from S5
gustavo_dias
Aug 2016
Minas Gerais
76
Hi all,
I'm trying to configure a CP1430 TF card, i already include the COM1430 in step5 but i have no ideia how to configure it. In siemenes manual say nothing about it. I'm using a TTY-USB cable for communicate with CPU (135u/928B), with this cable can I configure CP module? I need to plug in the cable in CP/PC or plug in CPU can I configure?
The doc don't show me the step by step, it don't explain the details.
I'm using S5-USB, it's a tecnatron device.
If the TTY doesn't work, i can use AUI cable to do this?
The "Commissioning and Configuring an ISO Transport Connection between the SIMATIC S5 and SIMATIC S7 via Industrial Ethernet" doc does show you step-by-step what to do to setup the CP1430TF. Look under the heading Configuration of the transport communication on the SIMATIC S5
I haven't encountered problems connecting to a PLC through VM Ware but I am with this particular machine. I'm running Windows 7 on a Windows 10...
135
Hi, I want to build a demo station to test devices and programs and I need some help with it. I want to connect GuardLogix, Piltzmulti and...
133
please using the usb can i assign any ip address that i want ?
142
Hi everyone, I need some help I new with omron plc. I using plc CP1L. When I do the program it's good and the plc is function as program. But when...
83
I have a piece of equipment that is operated by a PanelView Plus 600 HMI touch screen via RS232 into a Micrologix 1500 PLC. I am trying to...
141
