How to configure and programming to write bool values to siemens plc s7.300 via modbu
chuongbv85
Aug 2017
Ca Mau
Hi Sir,
I am using S7-300/400. I am usually using FC 03 and FC04 to transfer (R/W) bool values by moving them DBs. However i want to R/W bool values directly to plc ( slave) from master yoko dcs. I configured FC 01 and FC02 in slave slide ( write to Memory M) and used function A0 and A1 in dcs side. I cant write directly to M ( from M300.0 with 10 byeltes).
Thank you very much for yours help.
Literature.
To emulate a modbus server on a Siemens s7300/400 plc you need modbus libary from Siemens and that licence is expensive.
When the S7 is connected over ethernet to Yoko dcs using cp343/443 module on s7 site then this link could be helpfull.
https://www.sps-forum.de/simatic/14182-modbus-tcp-funktionbausteine-step-7-a-3.html
Used it for modbus tcp communication between S7 plc with CP443 and CTI plc acting as modbus client.
Kind regards
Henny
hi all i am new here i have a mitsubishi smart touch hmi i.e ms-60t-pe but i cannot find a software to edit and download a program in it any help...
153
Hello, I am trying to connect a Stride Analog Output module to a 1769 CompactLogix via Ethernet. I added a new Generic Ethernet Module for the...
225
Dear all, I am beginer in ifix hmi programming. I have 2 ifix 6.0 pc with license FiX and client.. Can some one tell me how to configure sample...
138
Hi all, the machine I am programming the Rockwell PLC for has about 100 parameters that need to be adjusted for every customer. I would like to...
20
1,937
Within the last week or so, PME has crashed whenever I try to open a configure IO screen. I am running V8.0 Build 6215. Offline configuration of...
384
