1783-NATR FTP woes
passwordg
Aug 2011
South Carolina
224
We started using a 1783-natr device on several machines, but only for going online with PLCs and Proface HMIs.
We also have some Fanuc robots I want to connect to via FTP but all FTP connections get denied, as if the requests get blocked by the natr. It works when going directly through the switch.
Someone was able to make this work in this thread by changing port settings but didn't elaborate how !
http://www.plctalk.net/qanda/showthread.php?p=753178
Apparently you can set custom rules for specific ports but I can't figure out where!
Any help please ?
EDIT:
Solved!
This is where the settings are: (See attachment)
Are you sure the "Fanuc Robots" can accommodate the "FTP" protocol?
The FTP protocol is usually on port 21.
You would have to forward port 21 to the IP address of the Fanuc Robot in the 1783-Natr.
This is just the basic's as I don't know anything about either.
Interesting, I was just dicking around with a NATR and noticed it blocked pings. I wonder if you could allow pings to get through this way?
Ping uses the ICMP protocol and most routesr block that from the WAN because this is how "BOTs" find your "Internet IP" address.
Once your Internet IP address has been found, you would be asking for trouble.
Standard FTP and FTPS protocols are Bi-Directional and multiple connections are made during transfer and these connections are initiated by both the client and the server and this can be an issue with NAT when traffic and ports have to be pre-defined.
You may be able to set up your FTP in passive mode PASV in which all connections are initiated from the client to the server only on defined port ranges.
SSH FTP or SFTP is the best way to FTP files when using NAT as the way things work under the hood are much more accommodating to NAT if your equipment supports it.
Are the default gateway addresses of the Fanuc set to the private port address of the NATR?
As far as I know this is essential for these NAT routers.
Is it possible to gather OPC data through a 1783-NATR? Searching around, it sounds like OPC data might be blocked by any NAT... Is there any work...
245
Good morning all, I have a project that has quite a few NATRs to configure. I would like to modify the generated backup config file because I...
424
I am trying to communicating with other PLCs on a public network from a CompactLogix PLC on a private network. I have installed at 1783-NATR...
552
Hello, I'm seeing some interesting behavior with my NATR connections on FTLinx. 2 separate cases are showing the same problem: The first NATR...
618
Hello, I have been trying to set up a NATR with 3 connections, I am able to ping the public IP of the NATR itself off of my network, but nothing...
674
