Kloeckner Moeller PS316, connect multiple RS485 devices
nickegeson
Dec 2017
Uppsala
I am trying to troubleshoot our old Kloeckner Moeller PS316 PLC due to some strange false alarms. I had a hard time getting the connection to work but finnaly succeeded. There is some info about this in this thread: http://www.plctalk.net/qanda/showthread.php?t=113254
However, the other annoying problem is that I only have one RS485 port on the PLC which during normal circumstances are connected to HMI panel. Problem is when I need to connect the computer I have to disconnect the panel which creating a bit of inconvenience as you want to see what happens on the HMI at the same time you troublehsoot the PLC software from the computer.
Is there any "quickfix" for this issue? Any adapters to use to connect more than one device to the network? Or can you build a cable that will make this work? And/or do you need to do setting in the PLC or the code to get this to work? As I understand the standrd RS485 should have the possibility to communicate with more than one device.
Dear forum, Is there anyone out there with some experience from old Kloeckner Moeller PLCs? I am in need of connect to a SUCOS PS316 and I have...
3,752
Hi group, We have a bit of an issue which I am sure you guys have heard before, I did look at the previous threads but could not see if there...
517
I am looking for leads on getting a manual in English for the Klockner Moeller VTP HMI software. The software is VTP and was DOS based. From what...
545
Hi, First i'm a beginner and not a very good in english so i will try my best to be clear ! I work on an used installation and me and my team has...
652
Hello! I have a friend who now lives on his boat in a different country and he has reached out to me for some help. I am familiar with the PS4...
1,597
