TwinCat examples for how to use TcMC2.lib functions to control motor/linear rail?
beoborg
Oct 2012
Tampere
I have Linear Rail/Step motor connected to my Beckhoff through EtherCat. I am just started to program this PLC systems. My project right now is to move "item" vertically, which is attached to this Linear Rail (Stepper motor)
http://www.isel-germany.de/products/product.php?lang=en&ID=p302
I have found couple examples from Beckhoffs infosys TcMC2.lib page. The first one "TwinCAT NC Sample PTP Move" is quite good, and using that I have tested my beckhoff system using same step motor, which is inside that linear rail.
http://infosys.beckhoff.com/english.php?content=../content/1033/tcplclibmc2/html/description/tcplclibmc_sampleprogram.htm&id=14149
I have tried to find more examples, but now luck. I am quite lost and stuck,
what to do next. Especially how can I be sure that my "item" does not move out side the rail borders? My device should have its "home" place upper end of the rail, and then it has 32 different locations where it should go when needed..
questions:
What kind of TcMC2.lib functions should I use in my situation?
I have now used MC_MoveAbsolute function, what might be the best in my case. There is 32 static locations and home. Maybe some struct/table, where should I put those positions
How accurate are those axis position values? After I have got my "item" to home place, can I use static position values, to drive The "item" there.
When program starts, how can I determine the outer limits of the rail?
There should be some kind of switches inside the rail, I think... Do I need to drive my "item" end to end first to determine outer limits, or is there something helpful in TcMC2.lib
How does the MC_Home function works?
P.S Does anyone know where to find more PLC examples for Twincat/Beckhoff
Hi, i'm really struggling to get any decent examples of the above. Can anyone help??
10,457
I am using twincat 3 to send some strings over TCP/IP. Where the server is a sensor and my PLC is the client. I noticed that the sensor didnt...
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
217
Hi! I am trying to run the 'SimpleSample' (https://infosys.beckhoff.com/content/1033/TF5100_TC3_NC_I/Resources/3438746891/.zip ) to understand the...
102
I am developing a library in twincat and one of the function uses IID_ITcVnAccess_TcVnPoint2_DINT and the definition of this type is defined in...
70
