Function Block Memory Allocation in Omron CJ1M PLC
scrambled
Jul 2015
Brisbane
108
Hi all,
I am trying to add a function block to a PLC program written for an Omron CJ1M PLC. However, CX Programmer has thrown a compile error saying that there is 'insufficient FB Instance Memory for Non Retain'. I've checked the 'Function Block/SFC Memory Statistics' and apparently adding the Function Block has caused the FB Non Retained memory to go 37 words over what has been allocated.
I managed to expand the Non-Retained memory allocation and shrunk the Retained FB memory allocation slightly to accommodate it. Right now, I have 7 words free in FB Non Retained and 12 words free in FB Retained. The PLC program is now able to compile without error. However, are there any possible implications that I should watch out for when I try to replace the currently running program on site with my updated version?
Thanks.
Hi! I am using a TM200CE40T PLC from Schneider to write data over Modbus. I have used Memory words (%MW) before using the Write variable...
534
Question for the Siemens experts. In an S7 safety function block, I'm adding two safety function blocks for emergency stops (F_ESTOP1, FB215)...
4,937
Hi, I am still confused when to use just simple memory tags or put it in a data block. The same, when to put your ladder logic in a function or a...
3,277
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
118
Please see attached file. I need this program in Function Block form but I am totally lost on this. Any help would be appreciated. Thanks!
295
