plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 2nd, 2019, 02:09 PM   #1
Dhitzfelder
United States
Dhitzfelder is offline
Dhitzfelder's Avatar
RSLogix5000 link with RPI
Hello, all.
I have purchased a Raspberry Pi, and intend to use it something like a high speed counter (It hasn't arrived yet). At this point, I intend to use the PyComm module to communicate with the PLC.
Question: from what I can see of the code, am I correct in assuming that the PI initiates all communication with the PLC? If so, is there any setup necessary on the PLC end other than creating tags to be read or written to?
Old February 2nd, 2019, 05:08 PM   #2
dmroeder
United States
dmroeder is offline
dmroeder's Avatar
You have the right idea, nothing will need to be done on the PLC end, all of the work will be done you the Pi.
Old February 2nd, 2019, 05:24 PM   #3
Dhitzfelder
United States
Cool, Thanks dmroeder!
Out of curiosity, is there another alternative that sets up the PI as an ethernet device for the PLC? I looked at setting it up for Modbus TCP as well, but from what I'm seeing on forums, that's a different language than AB talks...
Old February 2nd, 2019, 06:13 PM   #4
dmroeder
United States
dmroeder is offline
dmroeder's Avatar
There isn't anything that I'm aware of that would essentially let you add a Pi to the I/O tree if that is what you are thinking.
There are modbus TCP projects on github. Here is one (I've never used it):
https://github.com/sourceperl/pyModbusTCP
Old February 3rd, 2019, 12:28 AM   #5
kallileo
Greece
kallileo is offline
You can install Codesys runtime on raspberry pi and make either Modbus tpc client or server in order to communicate with your AB PLC. You can even use it as Ethenet/IP scanner or adapter.
https://store.codesys.com/codesys-co...ml?___store=en
__________________
automationofthings.blogspot.com
Old February 4th, 2019, 07:32 AM   #6
Dhitzfelder
United States
Kallileo, Thanks for the response. I'm going to play with it for sure , but from everything I can see, Allen Bradley doesn't talk to modbus TCU.
Old February 4th, 2019, 09:09 AM   #7
cardosocea
United Kingdom
cardosocea is offline
I believe AB does communicate via Modbus, but it's all done via software... as in you download a subroutine that will do that for you.
I had a look a while back and it looked ok. Not sure if it's only available through techconnect, though.
Have you checked pylogix for Python?
Old February 4th, 2019, 09:17 AM   #8
gothroach
Supporting Member
United States
gothroach is offline
Quote:
You can do Modbus TCP with Studio 5000, but it's not a built-in. Rockwell has sample Modbus TCP master and slave implementations on the KB. It takes a fair amount of memory, but I've used it in the past to talk to Modbus VFDs successfully.
Overview PDF from Digi
KB With Program Links
EDIT: cadosocea beat me to it! I'll leave the links though.
Last edited by gothroach; February 4th, 2019 at 09:19 AM. Reason: Beaten to the punch.
Old February 4th, 2019, 12:00 PM   #9
Dhitzfelder
United States
pylogix is probably what I will go with.
As I understand it, the PLC doesn't recognize it as an I/O device, it just reads/modifies the tags similar to the way a user would do so using the ControLogix software. That's fine, but the PLC wouldn't think anything's wrong if it doesn't get any input, so I'll have to incorporate a heartbeat and program error handling for no input.
As an aside, it looks like it would be much simpler to use the PI as an interface for any other modbus devices than to use the code provided by RS Logix to configure the PLC as a modbus...
Old February 5th, 2019, 04:52 PM   #10
Jeev
Australia
Jeev is offline
Jeev's Avatar
I'm interested in learning a bit more about the R-Pi <-> AB comms. What PyCom parts are you guys using?
Old February 7th, 2019, 08:36 AM   #11
Dhitzfelder
United States
Quote:
https://pypi.org/project/pycomm/
I started using PyLogix (available at GitHub), and it is much easier to impliment.
just create an instance of class PLC(), i.e.
myPLC = PLC()
assign an IP address to it:
myPLC.IPAddress = 192.168.30.1
write tags: (to a tag in the PLC named "test", the integer value of 1000)
myPLC.Write("test", 1000)
read from tag: (place value in variable "sample" in the pi)
sample = myPLC.Read("test")
good instructions are available here:
https://github.com/dmroeder/pylogix
Old February 7th, 2019, 11:52 PM   #12
dmroeder
United States
dmroeder is offline
dmroeder's Avatar
Your post got me thinking... Could I add a module to pylogix that would act as a real I/O device? The answer is yes, or at least I have a working proof of concept. In fact, I was able to make an EDS file that allows you to add a custom "pylogix" module to the tree, though I probably won't go that route since I'm not an ODVA member with an official vendor ID.
But if I can work out all of the details, I may add a module to pylogix that will connect with a generic Ethernet module.
Old February 8th, 2019, 10:28 AM   #13
Phil Buchanan
United States
Phil Buchanan is offline
Phil Buchanan's Avatar
I have a source for Pi drivers for Ethernet IP if that may serve better on the comms side. PM me if you want details.
__________________
PLC Boot Camp Training
http://www.KeyAutomationTraining.com
Old February 10th, 2019, 03:35 PM   #14
ASF
Australia
ASF is offline
I'd be interested in this!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Toshiba T3 PLC Computer Link <-> RS-485 (real time data extraction) vincentc LIVE PLC Questions And Answers 0 February 21st, 2017 01:47 AM
Omron Host Link question PLC_4_Ray LIVE PLC Questions And Answers 1 November 15th, 2016 12:20 PM
"AS-i Power Fail" at DP/AS-i Link silva.foxx LIVE PLC Questions And Answers 0 June 9th, 2009 08:40 AM
Serial Link between CJ1M and a CQM1H? Soggy Canuck LIVE PLC Questions And Answers 3 March 21st, 2009 03:28 AM
Rx3i and Omni Link press control jseavers LIVE PLC Questions And Answers 0 February 28th, 2009 01:12 AM
