Convert old 24AC pnematic solenoid valve to new 24DC solenoid valve with rectifier?
BrockSamson
Feb 2019
Pennsylvania
30
I have an old piece of machinery that has a 24VAC pneumatic solenoid valve (5 port, 4 way, single with spring return and 1/2 inch inlets and outlets). I am in a hurry to get a replacement and cannot find a manufacturer that keeps them in stock.
Could I use a rectifier or converter to change the power from 24VAC to 24VDC so I can just buy a 24VDC pneumatic solenoid valve replacement?
I am new to this stuff this might be a stupid question.
Thanks CLEM. I have seen that one but the problem was finding one in VDC so I guess the only option would be using a relay to drive an addition 24VDC power supply to power that particular one.
interface relay will make sure you don't fry anything in case the new valve need more power than the old one...Take a look in the controls, maybe it is already a relay that drive it ?
Hi all, I'm starting a project where I have to convert an old HMI to work on a new panelview plus 7. A person who used to work for us, but does...
2,843
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
90
I have an application using an incremental encoder and then I convert it to degree (0-360) using calculation program. For a while, the calculation...
239
Hi all. Me again still learning Rockwell. So I'll be polling an INT data array from a Modbus SE power meter with a L82 (with a Modbus ProSoft in...
56
1,383
Hello, could someone kindly convert the attached RSP files that are currently used for SLC 5 PLC into PDF please
528
