plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 13th, 2018, 07:05 AM   #1
IdealDan
Malaysia
IdealDan is offline
How to get IP address of Panel view Plus for the first time
How can I get IP address of Panel view Plus for the first time
Old February 13th, 2018, 07:15 AM   #2
Rob...
Supporting Member
United Kingdom
Rob... is offline
If it is new out of the box. Use the BootP tool by Rockwell to assign it an IP address of your choosing.
Old February 13th, 2018, 07:23 AM   #3
Phrog30
United States
Phrog30 is offline
It's set to DHCP out of the box. If you want static you will need to go to configuration and set it to what you want.
Old February 13th, 2018, 08:12 AM   #4
isiah_s
United States
isiah_s is offline
you want bootp. It is surprisingly hard to find. Turn off wifi, write down the mac address you want to find, and scan with bootp. After you find it assign an ip address. Verify you can ping that address.
Old February 13th, 2018, 09:31 AM   #5
jstolaruk
United States
jstolaruk is offline
Fresh out of the box, the config menu will be displayed. You can set your addresses there, don't need bootp.
__________________
"You can live to be a hundred if you give up all the things that make you want to live to be a hundred." Woody Allen
Old February 13th, 2018, 10:19 AM   #6
CaspianSage
United States
CaspianSage is offline
CaspianSage's Avatar
You may also be able to get the IP address with SADP -it's a free download and no Klingons to mess up your PC
__________________
Caspian
1+1 = 3 and I never was good at math.
Old February 13th, 2018, 08:16 PM   #7
JaxGTO
United States
JaxGTO is offline
if it's existing you can put this in a autorun.bat on a USB drive and plug it in. It will send the IP configuration to a text file called ip.txt:
ipconfig > \USB Storage\ip.txt
Old February 14th, 2018, 01:53 AM   #8
crawler009
Switzerland
crawler009 is offline
crawler009's Avatar
You can go to the configuration menu and see/set the Ip-adress. Access the configuration menu by clicking the white box after powering on the Panel.
EDIT:
Its not so easy in Rockwells world.
https://theautomationblog.com/how-do...guration-menu/
Basically, this white box was available for FW Versions 3.20 up to 5.1. Then they removed the white box again in FW 6.
In 6.1 they added the box again, but its disabled by default. Now you can connect a external Keyboard and press F1 to go to config mode.
Typically for Rockwell, if something works, it has to be broken. If something works bad, stick to it (the customer will get used to it).
Last edited by crawler009; February 14th, 2018 at 02:42 AM. Reason: Added details.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Changing Ip Address on Panel View and FactoryTalk Studio Kyle.L LIVE PLC Questions And Answers 3 November 2nd, 2017 05:00 AM
Creating a second LAN configuration for Siemens Lamboom LIVE PLC Questions And Answers 25 May 12th, 2016 07:32 AM
Panel View 300 Micro Comms Issue - Help! timtimmo LIVE PLC Questions And Answers 4 December 7th, 2009 03:22 PM
Time Synching Panel View plus 1000 dhanad LIVE PLC Questions And Answers 5 May 29th, 2009 04:59 PM
CLX Ver 16 and DH+ Panel View Donnchadh LIVE PLC Questions And Answers 4 April 16th, 2008 03:44 PM
