Alicat Mass Flow Controller- Micrologix 1400 programming
PLCGuy001
Jun 2018
The USA
Hello Everyone,
I have been working on this project lately which uses the Alicat mass flow controller. The Alicat flow controller is connected to the micologix 1400 PLC using a RS-232 cable and I am connected to my PLC using the LAN cable. Can someone help me set up the communication/programming so that my RSlogix 500 program can read IOs from the Alicat flow controller. I have never used this before so I am not sure if I should use modbus protocol, explicit messaging, or is there any other way to get it done. Please help!
Turns out the Alicat controller read and writes in ASCII. You just have to copy the files into String files and then convert it into float.
Hello, this is a long shot but worth a try. Has anyone interfaced an Alicat Mass Flow Controller with RedLion, using Modbus? I have placed several...
26
27,454
Dear All, I need a sample PLC program to count the output pulse of a mass flow meter so that a specific amount of mass (for example 100gm)can be...
147
How is it going y'all? So We have had a pesky problem with an EH 300 flow meter. We are using EIP to reset the totalizer, and for some reason the...
788
I need modbus communication tool for Yokogawa Rotamass Flow meter? can any one help me.
979
Is anyone here familiar with the S-Mass flow meters from FMC/Smither Meter? I am looking to interface with the "MicroPak" transmitter module...
1,874
