Hello, I'm Ki,
My English is not good, please understand me.
I have to upload program from 1756-l55/A because our customer deosn't have a original program to maintenance.
The processor firmware is 8.90 (Redundancy version) in RSLinx.
so, I installed RSLogix 5000 V8.52 to my laptop on Windows XP mode(Virtual)and then I did program uploading but I've got a Fatal error while uploading as follow.
There was an unspecified communications problem.
RSLogix 5000 has been taken offline.
Fatal Error!
Application Path:C:\Program Files\Rockwell Software\RSLogix 5000\Bin\RS5000.exe
Version: V8.52.00
Source File: aftrans_offline.cpp
Line Number:557
Error 0x80042938 (-2147210952)
R***E_CONTROLLER_STILL_REFERENCED - Controller still being referenced.
Press OK to terminate this application
I tried to upload from other processor (They have 2 CPU for redundancy) but have got same issue.
Well.. I googled solution of that issue but I did't get any infomation.
Also, There is no solution in Rockwell Automation Knowledgebase.
Finally, I did test downloading and uploading a new program that has just 1 rung of main routine.
There was no issues. It is totally perfect.
However, I can't upload it from processor that has file they want.
Please, Check attached files.
Anyone had this and found a solution?
Best Regard.
Fatal Error!
Version: V8.52.00
Line Number:557
Best Regard.
