Product Totalizer Logic using Siemens S7-300PLC
Coulombboy
Jan 2012
Makati City
70
Hi All,
I am currently working on a project of which we have used s7-300 PLC, and I am new to it. I need to provide a totalizer logic using analog signals coming from a weighfeeder. The totalizer engineering unit shall be in tons and weighfeeder signal is in tons per hour.
I have provided a 1 second pulses using a timer, and a math function that divides Tons/Hour into 3600sec to get Tons. And as my 1 sec pulse bit is true
the output ton will be added to the assigned data for the total weight of product produce. Unfortunately, I cannot make it work and i am having problem on some of the functions and these follow:
1. I have used FC105. In my HW config, analog inputs are 12bit. based on help fc105 input range is 0-27648 unipolar. Is this also the image of the analog input? 0-10V = 0-27648? 12 bit image is 4095. Can anyone suggest a better mean of scaling analog inputs?
2. For the totalizer, Im trying to do something which i have done using AB PLC. Let a = total product. And every pulse, i let a = a + b, where b is the quantity added to a. For this siemens plc, i have used the function ADD_R.
IN1 = md100
IN2 = md104
OUT = md 104
Where md100 = Weight delivered by conveyor every 1 sec in Tons
derived by scaling AI in TPH / 3600
md 104 = Total weight delivered by conveyor in Tons
Unfortunately it didn't work. MD104 do not update every 1 sec.
Should you guys done something alike, please let me know and kindly give me some advice so i can solve this problem. Thanks much in advance. (y)
Hello All, I'm looking for some opinions and Ideas for guarding the product entrance of a palletizing robot cell. Please see the attached...
478
Respected Members; I am going to design the PLC control system. The requirement as under: 1. Input/ Out put modules are SIL 2 certified. 24...
392
I've got an issue opening a project in TIA Portal v16. When the file is opening, I get the message that says "Optional products used in the...
627
I am new to Siemens, and just looking into their HMI software. Does Siemens have a product similar to FactoryTalk View SE? I am looking to have...
1,673
I am speccing out a system for some burner controls and the customer has two SLC500s that will need to be upgraded. There is no distributed IO. I...
25
6,429
