Hi. Could you help me to convert a simple ladder diagram into Pascal, C,or Basic code
Boyko Boykoff
Mar 2003
I am trying to convert this simple ladder diagram (for Omron Symatic 200) into Pascal, C or Basic. I want to use a PICmicro instead of PLC, but I can't convert the LAD into PICBASIC PRO. Could you help me please.
Thanx.
P.S. The LAD program is in attached gif file.
Sorry I don't know how to do a timer in BASIC. It is not equivalent to a DELAY, PAUSE, WAIT, etc.
IF v1 AND NOT v2 then [TIM0]
IF v1 AND NOT v25 THEN OUT v24
IF t0 AND NOT T1 AND NOT v0 AND NOT v3 AND NOT v5 THEN OUT v25
IF v25 AND NOT v4 THEN [TIM1]
Not quite.
IF v1 AND NOT v2 THEN TIMER(T0,100,1) ELSE TIMER(T0,100,0)
IF v1 AND NOT v25 THEN v24=1 ELSE v24=0
IF t0 AND NOT T1 AND NOT v0 AND NOT v3 AND NOT v5 THEN v25=1 ELSE v25=0
IF v25 AND NOT v4 THEN TIMER(T1,10,1) ELSE TIMER(T1,10,0)[/
The Timer function {TIMER(Done bit,Preset,Enabled)} is fairly complex. It uses at least 3 integer registers, one to store the preset, one to track the accumulated value, and one to track against the system clock (RTC), as well as other internal bits.
Code:
If Enabled = 1 AND Internal_Enabled = 1, then
    If (RTC - System Clock Track) > 1 sec (assuming your timer is on a 1 second time base)
    Then System Clock Track = System Clock Track - 1;
         Accumulated Value = Accumulated Value + 1
    If Accumulated Value > Preset Value
    Then Done Bit = 1
    Else Done Bit = 0
If Enabled = 1 AND Internal_Enabled = 0
then system clock track = system clock.
If Enabled = 0 Then Done bit = 0;
                    Accumulated Value = 0
Or something like that.
But one of the big keys about PLC coils is the fact that if the instruction is false, the PLC resets the bit.
"But one of the big keys about PLC coils is the fact that if the instruction is false, the PLC resets the bit."
Cheers Allen, of course... I wasn't thinking back to my old BASIC days - If one sets a value, it stays that way until modified. DOH!
i hope you could help me to convert the network Stl to lad it's apart from program of machine and i try to find solution for the reason of error...
1,852
Hello everyone, I am migrating a program from STL to SCL via S7-1200 portal, I would like you to help me by converting these lines of code...
1,607
Hi All i was wondering if any one would be able to help me. My version of studio5000 only allows ladder and FB. i have an AOI written in structure...
1,523
Can someone please help me out and print this entire program to a PDF. Tried to zip and upload but too big so Google drive Link below to the adc...
1,242
Hello, I am trying to figure out how to create / write / delete a .csv file on the SD card of an Allen Bradley PLC. There is a sample project...
1,414
