Hi, I'm designing an HMI using the Wonderware Archestra IDE (2017) and I'm trying to figure out the best way to use a user input to pass a value to multiple tags (object attributes as Wonderware calls them).
The user input only lets you write to a single tag but I was thinking I could write a script so that when the enter key is pressed it writes the entered value to the other object attributes. The problem I'm having with this is that I don't know how to assign the enter key as the trigger to execute the script.
Another option would be to have the user enter the value into a custom property tag and then use a push button to send the custom property to the various object attributes. I would prefer to avoid this method for various reasons.
If anyone has done something like this before your help would be much appreciated!
