Using UTP Patch cord cable instead of IE cable
Adenitz
Feb 2010
tir
41
Hello guys,
can I use RJ 45 UTP Cat 6 patch cable instead of Industrial Ethernet? The connector is broken and there wille be some deliver time to get identical replacement.
Original cable is this one.
And I have 10m patch cables like this one..
This cable is not shielded, but length is only 10 m and most of the cable is placed inside the control cubicle.
I have tried and it works, but wonder if there might be some restrictions or safety issues I need to watch out.
Thanks!
hi i would use a cat6 or 7 cable and make sure it is not routng past VFD cables or solenoid valves etc and then replace ASAP with correct one
+1
A cat 7 is the same and should cost less, also the Siemens cable is too rigid, you need a pipe bender when installing :)
Should be fine for now, but to avoid weird noise issues you do want to replace with a shielded cable at some point.
Hi, I'm trying to use the IO Device Library (Product Versions) which is configured to work with the 1756-EN4TR & 1756-EN2TR but my system uses...
40
72
84
Hey all, i have a panelview screen (image attached), with 4 items on it. Program 1, Program 2, ...3, ...4. The PLC i am using is a compactlogix...
158
I am trying to set up a piece of equipment with a Horner HE-X4R. I'd like to use structured text and so far I'm just trying to get a basic On/off...
67
