Differences between Rx3i embedded/on rack profinet controllers
2Faced
Oct 2018
Nha Trang
24
Hello,
I'm working on a project using Rx3i system and a third party profinet product. The previous jobs the third party products were connected to the Rx3i system via a PNC module and everything was working well. For this job due to some limitation I had to take out the PNC module and use the embedded profinet controller in the CPU (CPE330). Configuration was ok, Profinet DCP scantool discovered 4 devices in the ring (3 slaves from third party and 1 master the embedded controller) but I can't send or get data from the third party products.
The LD block PNOI_DEV_COMM is to check if the devices are talking together, as follows:
PNIO_DEV_COMM verifies whether the PROFINET Controller (PNC) identified by input IOController and the PROFINET IO-device identified by input IODevice are communicating with one another. If so, output OK is set to On; otherwise, it is set to Off.
My question is: is this LD block only applied to the PNC module ? Or can it be used with the embedded profinet controller in the CPU as well ?
Any advice is appreciated.
It seems like it should work for the embedded controller as well as the module. Did you configure the CPU's LAN2 for Profinet?
Make sure you use the correct name for the controller. To find the name expand the CPU configuration and click on the "Profinet Controller" item. Then look up the "Device Name" in the properties window (Inspector).
Thanks Steve for your reply. I was able to figure out and and fix the issue. The ref addresses of the third party I/O were mapped incorrectly.
Hi all. Currently I'm working on a VBa script for FTView. I would like to understand a bit better about some commands. 1) What are the...
595
Hi, I’d like to know the differences between these two plcs.
1,739
New to servo drives, wondering what the main functional differences are between the two types of servos. Any help even the most basic is very...
2,621
Good Morning , We had to change out a L61 with a L71 processor and it seems like our motion control is not the same . Have any of you run...
1,836
Hi all, "what are the differences between ABB, Siemens, and Honeywell PLCs?" I just saw this funny question on the net as an interview question...
3,248
