WAGO 750-881 and Wonderware
roxford
Mar 2019
acushnet, ma
Doing a project that will have Wonderware for our HMI. Is it possible to use Wonderware's OPC to communicate with WAGO 750-881 plc? I would think we can with OPC UA and modbus TCP, but not very familiar with OPC.
The Wago 750-881 only does Ethernet/IP or Modbus according to the specification, so you won't be able to talk directly to it using OPC UA, you would need an OPC UA server to sit inbetween Wonderware and the Wago unit. Kepware seems to get recommended quite a bit here.
Why not just use Modbus TCP?
because would also need this information to go to a Data Management Software uses an OPC interface
I guess then something like Kepware is going to be your best option. It can pull data from the PLC and serve it to Wonderware and your data management system.
Others may chime in and correct me, as I don't use Wonderware and haven't used Kepware, just read about it.
Thanks! no worries
Hi, I have never used modbus communication in Codesys 2.3, any tips and tricks are much appreciated. The system is a Wago 750-881 that controls...
1,845
Hello, Maybe it is just a simple problem, but I cannot solve it. I have a Wago 750-881 connected to a Beier HMI through IP TCP, the connection is...
891
Hello, I am new to WAGO PLCs and e!****pit. I am struggling to program a 750-881 PLC since I am unable to see/add an application under the...
2,343
I'm facing a problem with the 750-881 Controller of Wago. I created a visualisation ( page named plc_visu ) en it'shows up in the webbrowser. It...
1,711
Hey Guys, Im trying to work out the Modbus memory map and the tags on the Beijer x2 HMI and 750-881 WAGO PLC. Have looked up the forum and found...
4,315
