pcd2 programm cable ?
gm2012
May 2019
frankfurt
Hi i have a pcd2 . it has a "PGU" interface... 9 pins ..RS232.. i tried to connect my old pc .. but no connection! maybe i need the PGU cable ? pcd8.k111
kann i construct it by myself ?
thank u :D
thank you for your quick answer^^
yes of course i read this pdf !
i even printed it out :
but there is no final answer for me .. its like a big "?".
so i first i need to check how a rs232 - cable is wired. then i have to look if the programming-cable has the same wires.
(sry bad english)
i think i cant buy this anymore.. maybe hard to find
hmmm...
Page: 3-8
PGU port D-Sub socket, 9-pole1)(for PCD8.K111 programming cable) 1
1) Can also be used as a serial data port, e.g. to connect a terminal; but this hampers troubleshooting with the debugge
page 4-5
The PGU interface (Port # 0) is connected to a 9-pole D-Sub connector (female). The interface is used to connect the programming device when the unit is comissioned.The interface is of type RS 232c.
PCD8.K111 connecting cable(P8 and S-Bus protocol, suitable for all PCD1 / PCD2 units
Pcd2 pg4
now i think i did it...
But i really don´t know how to continue. I need to learn the PG4 program i guess. Because when i press yes it maybe copies the configuration onto the PCD... but it´s still in the halt Modus...
đź“š
PCD2_Versuch 2019-0528_anzeige_download_To_PCD.JPG PCD2_Versuch 2019-0528_confectionated_cable_PCD.JPG
Hi , i already wrote it in another post, i think i got a connection through my selfmade rs232 cable now i dont know how to programm the PCD2...
1,027
hi, i have a machine with SAIA model number PCD2.M5540. Recently i am facing issue regarding the run and stop mode. i tried setting the plc to...
1,811
Hello Friends I need to backup a SAIA PCD2 (pic attached). I have no experience with SAIA. Which software do i need? which cable? I have read...
1,913
Gents, I have a PLC and HMI from SAIA Please, see in the attached pics and tell me how to upload the programs to the PC (PLC and HMI) Tons...
2,272
helo sir /madam i have a old saia burgess pcd2 m110 plc.(1996) i down load the pg5 from the net and i am able to communicate .(i am able to upload...
3,335
