ABB drive to PC connection
moh251
Dec 2013
Jordan
Dears All
Please could any body inform me what is required to connect ABB drives ACS850 & 350to a PC, I need it to make back up for my drives,
What is the required cable and software?
I tried on Drive Studio but failed.
drivewindow light 2
I just used drivewindow light 2 ( free download ) and a usb to serial adapter and a straight rs 232 cable. Just had to setup pc com settings to match drives settings. worked fine
Thanks to all, I tried both programs but failed to go on line, any body can provide the exact pin out for needed cable
Hopefully you realize that those are RS232 ports and not Ethernet ports. We just buy the RJ45 to DB9 adapters and wire them per the attached drawing. Standard patch cable is used.
hello Sir,
Will this cable work with ACS850 drive. I Want to go online with ACS850 drive and i have DriveStudio Software.
kindly suggest the cable and procedure to communicate with ACS850 Drive.
R
We have drive application using ABB DCS500 dc drive with profibus protocol (using NPBA-12 profibus adapter module that support Profibus-DP and...
5,543
Members of this forum helped me out a great deal a couple of years ago with a question I had regarding acceleration during torque control of...
4,443
Hi all, I've been asked to take full parameter backups of a series of ABB drives for a customer. There's about 20 ACS355 drives, and then one...
3,335
