analog input in ladder logic
my program cycle-:
when 1st customer insert its biometric card then valve open and water start flowing .
when customer input is stop by(any like biometric/electromagnetic card)..cycle complete--- up to thid first process
2nd- if any probloem comes in flometer then then valve stop but customer identity is still saving in memory..if its long time (1-2hr) cycle complete
after it all how plc collect data from mainly from flowmeter and concert it to exact flow quantity..
if customer identification through rfid how to detect in plc just given me hints
plz share me details(ab plc 500),
thanks
iant
Timer values in PLCs hit a maximum around 65000. You need to make a second timer TON that automatically resets with the timer's done bit (timername.dn). Use this second counter on a count up CTU for minutes. When it hits 60 use another CTU for hours and reset the minutes.
This will be a free running timer that you will reset with RES.
When you get the input for water flow clear the timer and watch it start. This is the first place you should stop and test to make sure your timer works.
Once your timer works use compares on the timer Hour/Minute/seconds to stop the water at the given time specified by the project using compare values against the running timer and the timer setpoints.
Next you need to learn your flow meter and get it working. Which ever flow meter you buy, go look up the manual and see how it works. In some they give pulses and each pulse means X amount of flow. Count your pulses and do the math. Test this. Make sure your meter gives the proper amount of water per x pulse (i am assuming this is how your meter works).
Next you need to start counting pulses while your timer values are not equal and the process has been started.
This should count water flow for a given time.
Goodluck
I am sorry
I don't mind helping you.
But you need to do the maths
Let us know what products you are using.
Not a bad idea Jeremy.
But use a timer cct that generates a pulse every second or minute.
Using a real or floating point variable you can count well past 65000
By simply adding 1 to the source.
i need input from electromagnetic flow meter to plc (ab micrologix 500 plc) through rs-485 communication .. input may be pulse/voltage,,
how to it configure plz expalin me
sir'
iant
sir,
flowrate r not constant speed its a EMT flowmeter, its gives pulse input to plc ,let assume 1 pulse is 10L, then justgive me an idea how to do a program for it,
in ab plc 500,
and explain me hoa a pulse is configured
Dear All, I am new to this forum and want a help!!! Using Delta PLC (DVP20EX2 with 8DI,6DO,4AI,2AO) and want to use a Pressure Transmitter (4-20...
6,418
Hello to all I used to store the different mail you sent talking about various topics; among them "analog input" As I read it again,I would like...
5,357
I'm having trouble calming down 2 Tempo Sonics. I'm using Studio 5000 CompactLogix my Raw value is jumping around from 8575.0 to 8755.0 at a...
30
1,127
I cannot add SLC500 analog input tag (I: 8.3) to EZSeries Touch Panel Editor (V 5.3). I used all the listed tag datatype but it all says "Invalid...
257
Hi, I have questions. I have Analog Input that need to put into Ignition Designer. But I don't know how to put?
118
