Discrete processes : OPC Servers to database: historians or SQL database?
Christ0phe
Dec 2012
Brussels
Hello PLC, Historians and databases specialists,
We are looking for solutions to upgrade our current Labview-based application that takes data from PLCs through OPC servers and store them into a home-designed binary file structures, locally on a PC.
These are our specifications:
- All our processes are parts driven (discrete). We are not dealing with time-based processes
- One part is produced every 1min
- The data acquisition is triggered by the polling of a 'trigger' (counter) and when this counter increments the application get all related data. In other words, nothing happen during 1min (just the trigger scrutiny) and all data transfer is once per minute.
- Per cycle we are taking about 15.000 tags (16 bits words) per machine
- Per plant we have roughly 10 machines, all with a cycle time of 1 min. One PC today is connected to 1 or 2 machines. So 5 PCs per plant roughly.
- Emphasis given on the visualization of the data close to the machine to help the operator in his process adjustments. Here the operator needs to visualize all parameters for a specific machine cycle, overlay profiles (a profile is a serie of tags for a defined cycle), graph parameters against cycles or against time (but even against time the different points of the graph mean a specific part produced)
- We do not really have time constraints as to the time it takes to fetch and write the data into the database. It can take 10s, we do not really care.
- Open database so that people can make cross-machines analysis of data (data mining)
- Cost-effective solution
An internal discussion lead to considering that instead of writing into a local home-made Database we could simply write into a centrally located SQL database (located on a plant’s server).
I know that Historians could also be a way to go but do not understand the advantages that we would have especially considering the specs given here-above.
What solutions would you recommend to implement or to study?
Thank you very much to share some thoughts with me
Christophe
Visualization windows: the Labview application that we wrote provides several ways to visualize the data:
For the local user close to the machine under supervision, operators mainly use the 3 following windows of the application:
Window1/ All process data values for a machine (can be thousands of parameters) displayed for a specific cycle number selected. Displayed in a kind of two-columns table. The selection is either a cycle number or date/time (in this case the application fetches the cycle closest to the date/time requested)
Window 2/ Some parameters are what we call profiles ie. collection of consecutive tags. Those must be displayed as curves for a selected cycle. For example after each cycle we collect pressure profiles, each profile being 500 consecutive tags.
Window 3/ 5-graphs, each one able to display a parameter against cycle number or time. Even when time is selected as X-axis, each point will represent the value of the parameter for a part produced.
The application also gives the possibility to set limits on parameters (different limits for different products). Those limits are displayed in the graphs of Window 2 and in the Window 3 interface as well.
For more advanced users performing off-line analysis they use the same windows and also an interface that allows extraction of parameters into CSV files for further data mining.
Thanks again for your thoughts
OK your decision will be based on your requirements. .
Historians are used to log data and for data analysis. Most Historians are already built on a SQL database. So you can do queries build reports ect from that. The benefit is that you can investigate your processes and it is fantastic for faultfinding.
I would always try and stay away from custom coding and look at something off the shelf. You do get cheap Historians and the benefit to be able to analyze your process is great for improvement / optimization.
Thanks for your inputs,
The things with which I am a bit reluctant bringing an Historian into the picture is the fact that reading users' experiences and vendors advertisements, Historians are meant for:
- time-based recording (not the case in our processes, we use the Part as the reference)
- huge data throughput to database (not our case, we log data once per cycle, lets say every minute)
- Big volume of data: that is maybe (not sure) a pro for historian but I am not even sure. A typical plant includes 30 machines ranging from 100 to 10.000 tags to collect once per minute. It does not matter if the collection phase itself take a few seconds. Accoding to this: http://www.inductiveautomation.com/news/item/218 it is not clear that Historians bring an advantage...
I do not know if there are integrated tools (SQL analysis) that exist if we get rid of the historians and we go towards the SQL-only database.
Thanks again
Christophe
I have worked on similar project and can help you.
I am an expert in SCADA design and developement, specialized in Siemens SCADA WinCC.
What you are looking for is not a historian but a application specific highly customized SCADA developement.
I have engineered and commissioned very similar project. The screenshot are as attached. You can see XY table in background probably the way you want. And customer also wanted the scada to show current punching status on scada. So the popup window shows the current status of machine (red is one type of punch while blue is another type of punch) This does not use any historian but a well engineered SCADA.
If you can suggest a convenient time, I can show the working demo on team viewer.
Please clarify following :
1) Do you use OPC DA or OPC HDA for accessing your job profile.
If your old software uses OPC DA, then clearly historian is out of question.
2) Can your budget allows going for standard SCADA software like Siemens WinCC plus engineering? In either case I can help you. However if it is standard SCADA then engineering cost will be little less.
Hi Everyone, Thought I had it figured out but I came to the conclusion it would not work. Here is what I'm working with... 1769-L30ER Flow Meter...
24
681
I'm building a hydraulically-operated tractor-mounted boom that will be used to read temperatures within bulk material piles. To simplify the...
658
Hi Everyone, We are EDAC Electronics Australia and we provide wireless automation solutions and I/O distribution products, with expertise in...
762
Hello, I'm in the process of converting a slicer from an Ultra3000 drive to a Kinetix 5100 using the KNX software version 4.00. The current...
521
