Gotxreddragonx
Hello,
I have a Micrologix 1400 PLC and using RSLogix 500. Using a Multi Ranger Ultra Sonic Level Sensor and the input is moved to N7:11, then scaled from 3120 / 15,602 to 0 / 13.5. I also added the less than/equal to 3120 and greater than/equal to 15,602 and moving them into the appropriate spot to scale the input properly, which it does. Somehow it's still showing a negative number in the SCP output, which is saved to a Float.
