plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old October 14th, 2018, 04:19 PM   #1
bert123
United Kingdom
bert123 is offline
Benefits and Limitations of an AB?
Hi all, so I need a little help with knowing the benefits and Limitations of using the Allen Bradley slc 500 system when being used to programme a basic conveyor belt system.
For benefits, all I have is that this PLC is expandable and are industrial meaning there tough. For limitations, I know that the Allen Bradley slc 500 system doesn't have a good memory and of course, AB's are expensive.
Any other things I could talk about?
Thanks.
Old October 14th, 2018, 04:41 PM   #2
rdrast
United States
rdrast is offline
rdrast's Avatar
SLC?
It's on its way out you know.
I'd be using modern hardware.
__________________
How to ask questions the SMART Way!
Look First, Ask Second!
Old October 14th, 2018, 04:42 PM   #3
Peter Nachtwey
United States
Peter Nachtwey is offline
Peter Nachtwey's Avatar
I would use the Compact Logix instead. The RS5000 programming software is better but this may not be a factor for a 'basic' system. The compact logix may be even cheaper than the SLC500 because old products are hard to support. The SLC500 is obsolete.
__________________
"Living is easy with eyes closed, misunderstanding all you see...." Strawberry Fields Forever, John Lennon
Old October 14th, 2018, 06:15 PM   #4
ASF
Australia
ASF is offline
Sounds like a homework question...
Old October 14th, 2018, 07:32 PM   #5
Gene Bond
United States
Gene Bond is offline
Quote:
And I'd guess the subject is History!
Old October 14th, 2018, 07:35 PM   #6
bert123
United Kingdom
bert123 is offline
That's because it is.
Old October 14th, 2018, 07:46 PM   #7
sparkie
United States
sparkie is offline
Yea, but they are tough old birds.
Old October 14th, 2018, 08:20 PM   #8
Ken Roach
United States
Ken Roach is offline
Ken Roach's Avatar
Traditionally we are very hard on students who post their homework questions while making little or no effort to answer them or who conceal that they are HNC class questions.
But I'll play along.
SLC-500 is a "mature" product. The first controllers came out in the late 1980's and the most popular modern model, the SLC-5/05, was introduced in 1993.
That means it's durable, and in wide use. Walk into a factory in North America and there are probably SLC's and call up a systems integrator and somebody will have the toolset and know how to use them.
But that's North America. In other parts of the world, Siemens or Mitsubishi or Omron are the leading brands that have the same degree of wide adoption and familiarity.
The popular brands are not just tough and well tested, their wide adoption, long life, and broad availability mean that they can typically provide longer service without breakdown, and that parts will be available for a long time and on short notice.
If I had an SLC-500 controller module fail today, I could have a replacement in two or three hours because there's a stocking distributor in my city. Even the fastest Internet-only distributors would take a day. In some situations, a day doesn't matter. In others, the difference in parts cost could be eaten up in a few minutes of downtime.
Old October 15th, 2018, 04:13 AM   #9
cardosocea
United Kingdom
cardosocea is offline
You can say that the SLC500 is tried and tested and is reliable as a benefit.
Old October 15th, 2018, 10:43 AM   #10
Firejo
United States
Firejo is offline
Firejo's Avatar
Well Ken I can say one thing about your answer as it relates to homework, if he "cuts and pastes" it the instructor will know he's cheating.
Very well said and great points. What I would add is that although the SLC5/05 is a mature product it is still listed as active on Rockwell's website meaning there is no "discontinue" date. Having said that I'm guessing that a majority of sales of new SLC5/05 are for replacement, not new systems.
__________________
Go Hawks!!!
Old October 15th, 2018, 11:02 AM   #11
gas
United States
gas is offline
Kudos to Ken,
In my dotage I teach maintenance classes. I have had students that have had PLC classes at the local Community College from professors that have never been inside an industrial plant. Because of this site Bert 123 likely now knows more than his prof.
Old October 15th, 2018, 11:52 AM   #12
Rson
United States
Rson is offline
Are you sure you mean SLC-500 and not RS-logix 500? RS-logix 500 is the programming software for the micrologix line. The SLC-500 series (hardware) is being phased out, I believe. They are pushing to compact logix.
If you mean RS-logix 500 software, it is basic, but very capable. A controller isn't altogether expensive - I think a micrologix 1400 can be had for $500 or so. The downside to using this is limited ethernet support and you could reach maximum I/O easily depending on complexity of the application.
A compact logix (RS-logix 5000 software) would be a step up - both in capability and price. You have greater I/O options, and you have the flexibility of remote-IO over ethernet. You can also communicate with other sensors, drives, etc over ethernet and save I/O.
Old October 15th, 2018, 12:17 PM   #13
geniusintraining
United States
geniusintraining is offline
geniusintraining's Avatar
Quote:
Originally Posted by Rson View Post
RS-logix 500 is the programming software for the micrologix line. ..
Just to clarify... and the programming software for the SLC-500 line
__________________
www.PLCCable.com PLC Communication Cables, PLC Trainers, Fluke Meters, MicroLogix, ControlLogix, Siemens, Allen Bradley and more... all your automation needs... ((NEW)) After Market 1784-U2DHP Allen Bradley USB to DH+ and Gateways
Old October 15th, 2018, 12:48 PM   #14
Nova5
United States
Nova5 is offline
Quote:
Originally Posted by rdrast View Post
SLC?
At least its not a PLC 5... Although I think the damn PLC 5 where I used to work is Immortal. With power failures we lost some SLC parts, Micrologix stuff... but the PLC 5.. Never.
Old October 15th, 2018, 02:31 PM   #15
OkiePC
United States
OkiePC is online now
OkiePC's Avatar
Quote:
I've seen multiple PLC-5 submerged in rainwater and survive. The obsolete servo amplifiers in those panels didn't fare nearly as well.
__________________
It's not all the variables I am most concerned with, it's the undiscovered constants.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Benefits and limitations of Chosen PLC Demandfivehd LIVE PLC Questions And Answers 16 November 9th, 2013 10:17 AM
benifits and limitations danielstacey LIVE PLC Questions And Answers 8 February 21st, 2005 09:54 AM
