WinCC/WinCC Flex I/O information
barryoc
Nov 2009
Kilkenny
148
I am looking for help on displaying i/o information on a faceplate. If for example i click on a pump or valve i would like a section of the faceplate or another tab of the faceplate to give me further information like
1: Output address
2: Feebback address
3: Interlock Bit
4: Panel ID for contactor or solenoid.
Is this a case for a sql database and have WinCC retrieve this information? If anyone has any guidelines they would be greatly appreciated. I searched the net but could not find anything specific to this task.
Regards,
Barry
I guess you could do this with text list? Each pump or valve would correspond with a number, and that number would show the appropriate text from the list or lists.
I think that would depend on the screen you use. Not sure if they would count though. You only need one list for each of the four values, with 5-10k entries in each. (I think that is possible)
It would be a hell of a job though :)
I've been trying to find a way to do this around the net since I start learning WinCC, which is approximately 1 month ago.. Will be very happy to find an answer here..
Boneless
What about a large installation with 5-10k tags? Would this be to much for flex?
I think flex maxes out at 4096 tags, so yes, it would be too much.
You would need the full SCADA version of WinCC for a system that large.
This is for a small scada system. In a factory where i worked i have seen this done in WinCC V6. I'm fairly sure they populated the information from a text file or database, but this had thousands of tags (complete factory) The system i will be doing will have possibly 1k tags. I just thought it might be easier to do it outside of WinCC or flexible and read the information in.
Thanks for the replies folks.
I'm continuing my Siemens education. I need some help with compatibility details. My customer has a machine that was made by a company no longer...
4,039
Hello all. I mainly work with Siemens PLC's and panels for our machines. But now I am faced with a pilot project that has to be as price friendly...
8,987
Hi Folks. I have an older application that weighs pallets and prints labels for them. We used to capture the time/date of weighing, but we...
1,622
Hi, I have WinCC Felxible 2008 SP5 installed on my Windows 10. I want to program Simatic panel TP177B using USB transfer cable. But i can't...
2,116
Hi, Is there a tool out there to convert exported CSV files from HMI Alarms to new WinCC tags with alarms ? Kind regards, C
1,402
