Toggle Bit Not Working + Cannot Access Other Inputs/Outputs
mysticarcher
Sep 2018
CA
Hi All,
Newbie questions but I have two of them!:
1. I am unable to toggle the bit on I:0 (it keeps at 0). If I go into the data file and manually change it to 1, it quickly reverts back to 0. If I try to Force On, it doesn't start the accumulation of the timer so :confused:
https://i.imgur.com/M8jG3GG.png
2. It does not let me add new data files. I also cannot seem to access any other inputs and outputs besides I0 and O0 despite there being 20 inputs and 12 outputs.
https://i.imgur.com/NgVWYRT.png
https://i.imgur.com/bKHvZKi.png
Hardware is AB MicroLogix 1000 and software is RSLogix Micro Starter Lite 8.
You can't toggle an IO input bit, use a wire to force the input or use bits instead of actual I/O to test your code.
You can't add data files while online. You have to add them and then download again
I dont know what restrictions starter version puts on you, But I would expect some
Even while offline, I cannot add any data files. The option is grayed out. From reading online, I don't see any limitations of the Micro Starter Lite in regards to adding data files. The only limitation I found was that you can only use it on Micrologix 1000 and 1100 models. Any other possible suggestions?
I got the timer working now when I forced the input or changed it into binary and manually changed the bit from 0 to 1, but is there any reason why you cannot toggle an I/O input?
Right I did force the input and it worked, but I was just wondering as to why you can't toggle on an input.
Now the main issue becomes how could I access the rest of the inputs and outputs since it doesn't allow me to add any data files or specify anything other than I0 and O0.
Ok I got it. I can't add data files but when it says O:0/2 it means the second output. I thought the format would be O:2/0-15. So I really do have access to all of those inputs and outputs.
when you say you cant add data files? i think there are restrictions on size are in the free ver. but you should be able to add.
Hi, I'm just looking for a simple way to make a button in excel (via VBA I presume) to toggle a bit in RSLogix 5000. I just got FactoyTalkLinx...
529
EDIT: I suppose i should mention, RSLogix 500 V8.40, SLC 5/04 (1747-L542C) Is there is a way to use the FFL instruction in a way that doesn't...
862
I have a printout of some Control Logix code that I am trying to implement in Emerson Rx3i. The code involves resetting the Master node of an...
1,157
We have PLCs on the line and I am using Logix Emulate. No matter which one I am connected to I can not toggle or force anything.
22
12,408
Hello everyone. I'm trying to write a program in ST which would toggle a bit with one button. So when the button is pushed the bool sets to 1 and...
3,621
