Sysmac c200hx
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Hello All, anyone here have experience with Omron SYSMAC C200HX PLC/PC? It is a CPU64. My question is simple: am I able to "go online" with this legacy-looking device with something other than a hand-held unit? I am looking at an online booklet and it appears as though it is something I encountered in a CNC machine about 20 years ago, that required a hand-held device and a firm knowledge of BASIC programming knowledge. Thank you.
SYSMAC Support Software (SSS)
Name Specifications Model number Standards
(for C20, CP,
CK, C120, CH,
C200H, C200HS,
C200HE, C200HG,
C200HX, C500, C1000H,
C2000H, CQM1, and
CVM1)
3.5”, 2HD for IBM PC/AT compatible
Note: Version 1.0 doesn’t support the additional
functions of the C200HX/HG/HE.
C500-ZL3AT1-E ---
Found this info from a manual, (c200he-cpu42-e_operators_manual), I found with Google, so, I vaguely remember
software being available. It may be DOS only though, I just don't remember. Here is the name of another manual I found with Google,
C200HE_HX_HG_2004_W303-E1-09_OPERATION
Seems like I remember another software called SysWin.
i know none of the above info answers your question but maybe you can find the answers in one of the manuals.
Hope this helps.
If I remember correctly you also need a Host link interface to use 232 interface, I doubt this is still in production.
Edit: I have just realized that the HX has a 232 port so you don't need one ;)
You can also use Syswin or Omron CXP.
A search may find a free version of Syswin.
Host link's can be found on Ebay. Two types, CPU mount or rack mount.
Hope this helps.
+1 bluebyu
http://industrial.omron.com.br/uploads/arquivos/C200HE_HX_HG_2004_W303-E1-09_OPERATION.pdf
The above is the operation manual for the C200HX.
This CPU has a built-in RS232 port that can be used for programming. See the above manual.
The cable pinout is on page 424 - Section 8.2 - Host Link Communications. Note that the SG pin is 9 on the connector.
A CQM1-CIF02 cable can also be used instead of the RS232 port to connect the software to the Peripheral port of the CPU.
I hope this helps you out.
Regards,
+1 bluebyu
Regards,
Would you happen to know if I go online with this PLC, will it have descriptions available, or will it be strictly addresses and functions, with nothing to indicate what they are? I called Omron tech support and the gentleman told me that he is unfamiliar with this platform as it has been obsolete for quite some time.
The comments are not stored in the PLC. When going online you will only get the addresses and functions.
You would need the original program file for all of the comments.
Regards,
If you have the correct cable, you can go in through the DB9 connector.
Search MRPLC.com for an Omron semi-universal cable.
Port would need to be configured correctly.
gtsuport
gtsuport
I get that, I was just asking if anyone here has tried and succeeded using a Keyspan serial to usb device is all.
If the USB to Serial adapter has the FTDI chip it will most likely work no matter the make. But older non-FTDI chip units are less likely to dependent on manufacture and model.
My 2 cents
Hi guys, do you know if Omron Sysmac C200HX peripheral port supports the FINS serial protocol? Thank you Regards Mike
3,196
Hi guys, I have the following setup Omron Sysmac C200HX connected to a HMI panel using serial port. I need to access some data in the PLC...
8,553
Hi, I have been trying to run drive via Sysmac studio. I can ping the drive. I can see the logic bits going on/off as per command. But, drive is...
21
563
Good morning to everyone on the forum and happy new year. I'm trying to use the following functions in sysmac studio, because I need to enable one...
325
So, here's probably a silly one that I hope someone here knows. I am working with a SYSMAC NA5 HMI. (First time doing anything with Omron.) What...
505
