Workaround for having static ip address for simcard in siemens CP1242-7 GPRS
mamech
Jul 2015
Cairo
Hello
actually, I know that in normal computer networks, the dynamic ip address can stay unchanged as long as I am connected with the computer on internet using the router, and once I disconnect, the ip address changes. I have read somewhere that a person could keep his dynamic ip address on his computer for 3 months because he did not disconnect his internet for the whole period.
I thought that the same way can work with sim card used inside CP1242-7 GPRS . I imagined that a simcard gets also dynamic ip address and as long as I am connected it does not change.
are not there any workaround to stay with the same ip address without buying fixed address sim card (it is really expensive here).
The main target is to have a several siemens PLCs S71200 with CP1242-7 GPRS modules to have static ip addresses, so they can communicate directly with each other using GPRS
this can be done??
thanks
Referencing KB document QA9877: "...FactoryTalk View SE Graphics supports single precision floating point values, and by default only provides...
1,787
I have an Allen Bradley temperature switch that I am trying to use in studio 5000. I am getting the message "Unable to interpret the IODD file"...
45
I copied a panel in factory talk HMI for an identical system. The label names are still the same as the original panel but I am trying to change...
126
Hi All, Firstly… Merry Christmas to all of you! Secondly, as some of you may have noticed I made some modifications to our backend to address...
29
7,073
Hi Everyone, I am supporting a system which runs on a SLC 500 (1747-L532). A fault has developed whereby the output state of some digital outputs...
992
