Machine won't start after problem
Johanna
Sep 2002
Conc.: A control mechanism tells the PLC - with the aid of a timer - whether or not goods have passed within the 8 sec.
If not, machine must stop.
Hello,
First of all I must tell you that I'm a big-time newbie.
Am in the process of learning: Siemens, Simatic/S5 version 7.2
A neighbour of mine is building a machine.
He knew I was making programs with Paradox/Object Pal.
So he asked me whether or not I could help him with above mentioned program.
Well, it's a new challenge, so I said I would try.
Secondly I must say I never had a technical education (or computerprogramming for that matter), so I am a self-taught programmer
To test things my neighbour put together a "machine".
PLC=Simatic S5 100U CPU102.
OK, well here's the problem:
Machine does stop when no goods have passed the installed eye.
All the outputs(relays) are reset.
All the flags are reset (as far as I can tell)
I now push on the Start-button:
- test mode/PC monitor shows zero's changing into one (1), as should be.
- the actual relays do NOT react, stay zero. :(
Two days now I've been trying to solve this, but nothing helps.
Must be overlooking something, but ran out of ideas.
So I hope you can point me in the right direction.
Thanks in advance.
Johanna.
PS. Shall try to enclose what I've made so far.
Conc.: A control mechanism (eye) tells the PLC - with the aid of a timer - whether or not goods have passed within 8 sec. If not, machine must...
8,793
So, a WW PC's hard drive decided to go bunk. The local tech did use Windows 7 Back and Restore to save an image. However, the restored image...
1,016
Hi guys, I had View studio 6.00 and it was working alright but we were forced to switch for 5.1 because almost all of our panelview are old. So...
5,750
Has anybody used one of the range of devices from ****, the Talk2M website and their VPN software, eCatcher. It looks like the combination solves...
2,012
Hello Everybody Anybody knows where I can get this version of SoMachine? The new machine expert version won't open my project saying there is a...
36
