(WinCC Enxternal tags communication)-SIMATIC S7 PROTOCOL SUITE
john86h
Sep 2012
Nevada
Hi guys
  • Project: I created new single project with WinCC v6.0 and added two binary external tags under MPI. (One for M0.0 and another for Q0.0, I don't use any hardware)
Then I opened up Graphics Designer, created two circles for creating on/off lamp! and an on/off button, and I assigned the external tags to the objects.
the program worked properly for internal tags but for external tags just for one time... then I couldn't.
  • Problem: when I click on runtime mode, the on/off button isn't active! (even when I download and run-p the PLC-SIM) I checked every thing more than 100 times!
in addition I succeeded to get a good result for one time, and the external tags connections were OK! but when I create a different WinCC project with the same configuration, objects and tags, it simply doesn't work and the external tag connections don't establish. I have no idea why. Did I miss something?
Does anyone happen to know how to install the graphic picture in HMI when I go into blower selection there are no graphics shown not only blower...
61
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
61
I have created a project in TIA Portal v16 Upd6 with S7-1200 (6ES7214-1AG40-0XB0) and WinCC Unified (PC station). The communication between the...
142
I am creating a project with WinCC Unified v16 Upd6 (PC runtime) with an S7-1200. The communication is good between the PC and the PLC as I can...
189
hello s7-400h and wincc are connected to each other via Ethernet. I need help on how to do time synchronization
51
