Networking AB PLC's
cornbread
Feb 2007
madison, indiana
407
Excuse my lack of knowledge in the world of networking PLC's, I'm old school where you take the laptop to the PLC. I have a variety of AB PLC's I would like to link together on one one network. Is it possible to have AB PLC2's, PLC5's, SLC500 and micrologix on the same network? If so how? Could I also throw on a Seimens S5 on the same network. As alway any help is grealy appreciated!
There are many possible options, but before answering anything you should investigate EXACTLY what PLCs you have. "PLC5" and "SLC500" can mean many things.
And then, investigate if the available ports on all these PLC are already in use, or are free to use. ANy existing networking should be carefully mapped out.
PLC2 may be the most difficult to "network". Maybe a replacement is overdue ?
Depending on your SLC 500, you could have all that on a Data Highway. PLC 2, PLC 5 and SLC 504 all support DH+. Im sure you could get the micrologix on there to somehow.
SLC 504. Like i said does.
Does the PLC 2 not support DH+? I was under the impression that it did (and was one of the only Comms protocols that it did support). Not that i have ever used one mind.
In my recollection, PLC-2 controllers had a front port with a differential serial driver that you could connect a 1784-KT or later a 1784-PCMK to.
You had to add a module to the PLC-2 to allow RS-232 connectivity (1771-KG), or the original Data Highway (1771-KA2) or Data Highway Plus ( 1772-KA3).
I'm not sure what the original poster's intent is. Depending on the mix of gear and his infrastructure, RS232/Ethernet converters might make sense, or DH+ bridges.
A project to inventory the control hardware in the plant is a great idea. You're going to find stuff you didn't know existed ! This forum is a great place for ideas and experience, so provide as much detail as you can about the controller models and what they're already connected to.
A PLC-2 needs a 1785-KA to connect to DH+. As Ken points out.
The PCMK and KT cards connects to the PLC-2 via DH, not DH+.
I think the effort would be better spent on replacing the PLC-2 with something newer.
I didn't know there was an original Data Highway (not DH+)
I have a question about IP addressing and Networking. I have a PLC with following IP address 10.1.0.120 this is an static PLC PLC is working like...
1,991
Hello all. I have a system with 4 different machines, each has their own PLC. I also have a RC in this subnet also. I created a server PLC that...
462
Hello All, I have two CompactLogix that I would like to network together however, they have different IP subnets. Is there a way to connect them...
4,429
Hello All. I need to network two CompactLogix on different subnets. One is 192.168.1.22 and the other is 10.10.30.15. Since I have to bring a...
1,770
Hi Every one I want to hookup the 10 numbers S7 300 PLC CPU on MPI Network . CPU,s are running on 10 different machines with 12 " HMI on each on...
2,117
