plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Unread October 17th, 2019, 07:54 PM   #1
Electricfred13
United States
Electricfred13 is offline
EasyBuilder Pro/Ignition/MQTT
Hello folks,
I am working on an HMI application in EasyBuilder Pro using the software with the Simulation mode as an MQTT Edge Gateway.
This simulation is communicating to a PLC which is then sending data over to the Scada software Ignition. I have successfully been able to Publish data points through the simulation to Ignition through the HMI but can not seem to write back to EasyBuilder Pro. Any thoughts?
So essentially a subscribing issue.
Thank you!
Unread October 17th, 2019, 09:01 PM   #2
gclshortt
Canada
gclshortt is offline
gclshortt's Avatar
http://www.multiprojekt.pl/ftp/weint...rManual_en.pdf
The above may help you out.
Regards,
__________________
Garry
https://www.accautomation.ca
Connect with us on Facebook: facebook.com/accautomation/
Unread October 17th, 2019, 09:06 PM   #3
damica1
United States
damica1 is offline
Make sure you are using the "Sparkplug B" MQTT protocol, if not - Then there will be several other steps involved to allow a Write Back.
__________________
David M. Camp
Unlocking the power of IOT in Oil & Gas!
Unread October 17th, 2019, 09:26 PM   #4
damica1
United States
damica1 is offline
Here's a screenshot. (Now I don't think every Weintek/Maple HMI has the capability of "Sparkplug B" MQTT 3.1.1)
But using this version and protocol it will work flawlessly. (As this is what I use for the oilfields)
__________________
David M. Camp
Unread October 18th, 2019, 09:32 AM   #5
Electricfred13
United States
MQTT via Sparkplug B
I went ahead and used the Spark Plug B vs. The Normal MQTT. That did the trick.
Solved!
Thank you
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Weintek EasyBuilder Pro HIM ComapctLogix Tag import bgtorque LIVE PLC Questions And Answers 2 October 9th, 2019 05:48 PM
Easybuilder Pro Rockwell Tag Import Kev77 LIVE PLC Questions And Answers 2 January 8th, 2019 02:26 AM
Easybuilder Pro questions manin LIVE PLC Questions And Answers 3 December 17th, 2015 04:37 AM
Easybuilder and XY Object AdamRuck LIVE PLC Questions And Answers 1 July 30th, 2015 05:23 PM
Micrologix 1100 and EasyBuilder Pro HMI technojuggler LIVE PLC Questions And Answers 10 May 14th, 2015 04:43 AM
