This project should be pretty simple. Just need decide if I’m going to make it a batch or countious system (or both and let the customer select the more)
It’s a pretty small system (200 gallon tank).
The waste stream volume rate is unknown yet, but it’s going to be a rinse water that is slightly acidic. I’ll dose NaOH to adjust the pH.
What’s the most common mode for a system this size?
Batch - wait til the volume reaches X % then adjust he pH and close all stream coming to the tank. Drain, then open feed valves.
Continuous - as long as volume is in between low and high, and pH is under setpoint for x amount of time. Adjust and drain until more waste comes, close drain and do it all over again.
