plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old November 14th, 2017, 08:52 AM   #1
babido10
Morocco
babido10 is offline
Help!!! convert code javascript to python
Hi all ;
if someone here can help me to convert this code to python
code:
public static libnodave.daveOSserialType fds;
public static libnodave.daveInterface di;
public static libnodave.daveConnection dc;
public static int res;
public static byte plcValue;
public static int memoryRes;
public static byte[] memoryBuffer = new byte[16];
public static void connectTo()
//fds.rfd = libnodave.openSocket(0, "192.168.X.X");
fds.rfd = libnodave.openSocket(102, "192.168.X.X");
fds.wfd = fds.rfd;
di = new libnodave.daveInterface(fds, "IF1", 0, libnodave.daveProtoISOTCP, libnodave.daveSpeed187k);
res = di.initAdapter();
dc = new libnodave.daveConnection(di, 0, 0, 3);
res = dc.connectPLC();
if (res==-1)
System.Windows.Forms.MessageBox.Show("Erreur de connexion");
else
//memoryRes = dc.readBytes(libnodave.daveFlags, 0, 0, 1, memoryBuffer);
memoryRes = dc.readBytes(libnodave.daveFlags, 172, 0, 1, memoryBuffer);
plcValue = memoryBuffer[0];
dc.disconnectPLC();
di.disconnectAdapter();
libnodave.closePort(fds.rfd);
Old November 14th, 2017, 09:07 AM   #2
azetou
Algeria
azetou is offline
I suggest that you try in here https://python.developpez.com/ it is a very good programming community.
good luck.
Old November 14th, 2017, 09:08 AM   #3
gclshortt
Canada
gclshortt is offline
gclshortt's Avatar
Use a online converter for this:
https://github.com/PiotrDabkowski/Js2Py
http://piter.io/projects/js2py
Regards,
__________________
Garry
http://www.accautomation.ca
Connect with us on Facebook: facebook.com/accautomation/
Old November 14th, 2017, 09:24 AM   #4
mts5096
United States
mts5096 is offline
That's not Javascript, it looks more like Java. But the System.Windows.Forms call means it's probably C#.
What are you actually trying to do?
Old November 14th, 2017, 09:33 AM   #5
BryanG
United Kingdom
BryanG is offline
According to his other post he is trying to get Python to work with Libnodave. Libnodave is a library that allows you to read/write data from/to a lot of Siemens PLCs.
Never tried it but here is a Python wrapper for Libnodave:
https://github.com/netdata/python-libnodave
and another:
https://pastebin.com/p6q0te6R
Old November 14th, 2017, 09:50 AM   #6
babido10
Morocco
babido10 is offline
Old November 14th, 2017, 09:51 AM   #7
babido10
Morocco
babido10 is offline
and another:
Exactly man wanna trying to do communication python with PLC
Old November 14th, 2017, 09:55 AM   #8
babido10
Morocco
babido10 is offline
Quote:
Originally Posted by gclshortt View Post
Thank u
Old November 14th, 2017, 10:02 AM   #9
babido10
Morocco
babido10 is offline
Quote:
Originally Posted by azetou View Post
good luck.
Thank u
Old November 14th, 2017, 03:15 PM   #10
damica1
United States
damica1 is offline
I know nothing about Siemen's Plc's. But do they have a MQTT Driver? Open Automation does I know.
My point is Python has some very good examples of subscribing to MQTT Brokers and doing just about anything you want with the data.
__________________
David M. Camp
Marshall Electric / www.mei-tech.com
PLEASE READ: https://www.prlog.org/12642091-marsh...-industry.html
PLEASE READ: https://www.prlog.org/12680572-marij...hold-word.html
Old November 14th, 2017, 04:31 PM   #11
boneless
United States
boneless is offline
You made me google it... https://github.com/RoanBrand/MQTT-Siemens-S7-300
I guess anything is possible if you create the correct program . Never even thought about doing this with Siemens.. I use it all around the house for sensor nodes and my sprinkler system (NodeMCU & Arduino).
Now I know what my next project is going to be . Thanks
Old November 15th, 2017, 02:41 AM   #12
BryanG
United Kingdom
BryanG is offline
The bit that didn't come across from his other post is that he is using a USB connected MPI cable. I think I would split the problem in to two parts, first work in libnodave to make sure that the USB connected MPI cable connection can work with libnodave. Then try to get libnodave to work with Python. There are some simple test MPI programs in the libnodave Dot.NET folders that I converted to get working with PPI to an S7-200. If you search here on plctalk.net for libnodave you will find at least one working program that uses libnodave.
Just found this note in the libnodave usb2mpi-Linux-2.6 folder:
Quote:
siemens-mpi.ko is a module that allows to use the USB to MPI adapter 6ES7-972-0CB20-0AX0
from Siemens under Linux. It was written for kernel 2.6 and tested under 2.6.13.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Been asked to review some code, looking for a sanity check with pump/valve control defcon.klaxon LIVE PLC Questions And Answers 7 November 6th, 2016 05:39 PM
Bar code reader and PLC dayanyan LIVE PLC Questions And Answers 8 December 27th, 2010 11:11 PM
S5 to s7 conversion, but the code is locked!!! mo_mesbah LIVE PLC Questions And Answers 43 August 7th, 2010 02:56 PM
How To Convert Leader To Hex Code (Please help..) genhits LIVE PLC Questions And Answers 5 July 3rd, 2002 08:00 AM
How to simulate a FOR..NEXT loop? New2PLCs LIVE PLC Questions And Answers 26 May 9th, 2002 12:36 PM
