plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old November 14th, 2017, 03:57 AM   #1
moamed
Egypt
moamed is offline
Read Many CHAR using INPUT_CHAR FB Unity Pro ???
Hi Guys
We work in a project using premium CPU TSX P57 4634M
and we want to connect to new device (AminoSys, Evonik) and
the supplier recommend to use PCMCIA card, character mode
So we have to use INPUT_CHAR to read data from this device
it's first time to me to use this function and I read a lot of information about it
but I don't know how to read many different Chars using one Function
I mean in Read_Var Block we receive data in array and every register data stored in one INT of array
but in INPUT_CHAR we receive in one String variable
To illustrate what i mean in attached files there is pic show the 22 different byte we need to reed
Thanks in advance
Old November 14th, 2017, 05:40 AM   #2
chud
South Africa
chud is offline
chud's Avatar
You will have to manually extract each bytes values and move them into your own string variables. Then convert them to integers to actually do some calculations or compares etc.
Thats the downside of serial character mode or ascii
You can use functions like delete_int or concat etc. Have a look in your library for string functions.
Manual coding awaits you
Old November 14th, 2017, 05:47 AM   #3
moamed
Egypt
moamed is offline
Thanks Chud for your reply
Old November 14th, 2017, 08:50 AM   #4
moamed
Egypt
moamed is offline
But now there is a problem that the max length of the String is 16 digit or CHAR
where in my case the device send at lest 22 digit this mean I have to receive it in more than one String ????????
Old November 14th, 2017, 10:45 AM   #5
Lare
Finland
Lare is offline
Nope. Default string lenght is 16chars. You can have longer string variables if you configure data type string[22] or string[50] and so on.
On animation view string can still show 16characters also for longer string types but with string blocks you see that there is every character.
You maybe can construct array of string (array 1..11 of string[2]) and Unity divides string to different bytes. (This is wild guess, I haven't tested)
Old November 14th, 2017, 11:05 AM   #6
Lare
Finland
Lare is offline
Tested with simulator.
On variable editor
string_test1, ARRAY[1..11] OF string[2], %MW0
Works easily. there is 11 different elements.
On communiation block you use string_test (Full array)
Characters are divided to string_test1[1] / %MW0, string_test1[2] /MW1 .. string_test1[11] /%MW10 variables.
You can also defide string without address.
Also string_test2, string[22], %MW0 gives same result, but now you can only use %MWx addresses on program side.
On variable side you can have string_int variable with %MWx addressing,. String is converted to numerical result automatically.
string_test3, ARRAY[1..22] OF string[1], %MW0
This divides string to 22 different chars.
string_test4, ARRAY[1..11] OF string[2]
This divides string to 11 different chars, no %MW memory used
Lot of choices
Old November 15th, 2017, 05:01 AM   #7
chud
South Africa
chud is offline
chud's Avatar
"On variable side you can have string_int variable with %MWx addressing,. String is converted to numerical result automatically."
Very nice never knew that.saves some time
Old November 15th, 2017, 08:34 AM   #8
Lare
Finland
Lare is offline
It works because on Unity you can have several different name and type variables with same memory address (%MW or %M)
Haven't used it, but it should convert to hex based number.
Only disadvantage is that it uses %MW side adressing and values are transferred between different variables on backgroud and it isn't showed on logic code.
Also Unity gives warning of multiple use of memory address (You can disable warning from settings)
Another way is maybe to use variables with alias naming.
3rd way is to use array of strings and converting string to numerical values with blocks. Using arrays save time, because there is no need to divide string to different parts with string block commands.
Because Unity is symbol name based PLC, using string with arrays (without any %MW adressing) is maybe best.
Even that using %MW "indirectly" also works
(using %MW is more for old PL7 which was memory based PLC)
Old November 19th, 2017, 02:49 AM   #9
moamed
Egypt
moamed is offline
Thanks Guys I really appreciate your time
Old November 21st, 2017, 07:51 AM   #10
moamed
Egypt
moamed is offline
Quote:
On variable editor
Lot of choices
I'm Sorry sir but I try to do what you mention but Function (INPUT_CHAR) didn't accept Array of strings tags, it accepted only String tags
Like attached Pic
Idea of Array of String will be very helpful as in this case each byte or Char will automatically stored in element of array
So I hope it work but it didn't
Did I do any thing wrong ???????
Old November 21st, 2017, 12:30 PM   #11
Lare
Finland
Lare is offline
I haven't tested this with character read and write blocks.
Simulator showed that it would work, now with real M340 CPU I see that there is coping problem between different string formats.
If string has first value 'abc' it will copy to different object.
If I change value to 'abcd' if will also copy to second string (both strings have %MW address)
Now if I change value to 'aa' it copies to 'aacd', old characters which isn't there anymore stays on second string
Looks like you need to code with long way, concat, delete, etc.
Old November 22nd, 2017, 06:16 AM   #12
chud
South Africa
chud is offline
chud's Avatar
or use the gest management bits to clear the data (move) you are writing to 1st before writing the next time
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Schneider Momentum & Unity Pro MATT116 LIVE PLC Questions And Answers 2 February 24th, 2015 08:57 AM
Schneider Unity Pro - DFB / DDT / Arrays majorv LIVE PLC Questions And Answers 9 February 16th, 2015 05:12 PM
Unity Pro XL 5.0 and Windows 2008 R2 kutuz LIVE PLC Questions And Answers 3 July 21st, 2011 03:04 PM
Schneider - Unity Pro - Citect etc BobB LIVE PLC Questions And Answers 11 January 15th, 2010 03:13 PM
Unity Pro XL - read only variable issue SCADA_Dude LIVE PLC Questions And Answers 5 March 28th, 2008 07:18 AM
