What is needed to connect a laptop computer to an slc500
wonder_dog7
Sep 2002
ALBANY NY
I used to trouble shoot Ladder logic programs on ocassion. The laptops we used were already set up to communicate with the SLC500's so I never had to deal with setup of them.
I have an SLC500 now and would like to know what is needed to down load programs to it. Is there any other way than using a PCMK card as they are very expensive? From what I understand rslinx-lite can be used to down load programs. What is the differences between this and the regular rslinx?
You will need to use RSLogix 500 to view and/or modify the program. The interface hardware to get the computer to talk to the SLC can be a 1747-CP3 cable which will connect your PC's serial port to channel 0 (9 pin 'D') of a SLC 5/03, 5/04, or 5/05.
If you have a fixed 500, 5/01 or 5/02 you can use a 1747-PIC to connect from your serial port to the RJ-45 port of the SLC. If you go this route you'll need to pick up an adapter as the PIC has a 25 pin connector and your PC will, more than likely, have a 9 pin.
The PCMK can also be used, as you already know, to talk to a 500, 5/01, or 5/02 with the PCM4 cable or a 5/04 with the PCM6 cable. The 5/05 has an ethernet port on it that can also be used to program through.
RSLinx lite just has comm driver functionality. Any other version (gateway, pro, ...) has added dde/opc capability.
Hope this helps.
Thanks for the info. What does the pcmk card do for you different than the 1747-pic cable? Im wondering on account of the fact that the pcmk card seems a lot more expensive. How do I plug the 1747-pic cable into the laptop computer?
I use a 1747-PIC and what you need is a laptop with a serial port. I think AB says a USB to Serial adapter won't work, so if your laptop is fairly new and doesn't have a 9 pin serial port this won't be the way to go. The serial port connects to a 9 pin to 25 pin converter which is connected to a ribbon cable for the PIC. The cable coming out the other end goes into the SLC. Right now they are going for about $100 on ebay for the complete unit. Don't buy one without the adapter or the cable, anything AB is worth it's weight in gold.
Hi all, A client has an existing pump house with a GE 90-30 PLC controlling things. I need to connect to it and extract the code and tags from...
2,517
I have an old PLC (circa 2007) consisting of Telemecanique/Modicon/Schneider Electric devices. The system has developed errors and unfortunately...
225
We're upgrading an old PLC-2 system programmed in ICOM. We have the files, the PLC logic is in a .LAD format. Does anyone have working...
422
I noticed something that’s mostly just a curiosity. Maybe someone here knows. An IT system is reading a L82 with the on-board IP and 1,0 added...
684
I've had a catastrophic HMI computer failure. It was running Wonderware In touch from around 2014 on a very important machine that I use. I've got...
800
