EB PRo error
Greg7683
Jun 2018
Plainfield IN
355
GZHAs2cjS7AAAAAElFTkSuQmCC
I am trying to upload a program from the HMI to a usb and open it in EB PRO but I get this. It is a maple system HMI5070NL v2
I have the latest version of the software.
EB Pro is for Weintek, Although Weintek make the maple screens I don't think the software is the same. I used to use the maple screens and now use Weintek and I can't open any of my old maple projects with the EB Pro.
Try EZware 5000 software
EB Pro works fine for mr for the most part I have always had problems with trying to down load and upload using a usb stick even with the weintek HMI's have the same errors
When I tried several times it never actually copies the program like it does with the cable it says it copied it but it's never on the flash drive
hello, I'm a student and for my final grade I have to repare a sepro robot. the only problem I have for now is that i have an error code 3...
35
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
401
Here's the skinny. I'm running Unity Pro XL v13.1 in a VM. I installed PlantStruxture GPL for Unity 2018 and am using those FBDs in a new program...
1,532
When I want to store the hwc file to the PLC an error apears and said the firmware 5.03 is incompatible with versapro, and the minimum version...
3,161
Hello everyone, I am having a problem with my Unity Pro v.11. When I try to open the software I get this fatal error: Unity Pro XL Fatal error...
10,457
